Teechart Pro 2011 XE2 installs only Standard
Blue
Post by Blue » Fri Oct 07, 2011 8:03 am
For some reason, only the standard TeeChart is installed in Delphi XE2.
(Windows 7 64, Delphi XE2, Teechart Pro 2011 XE2 installer)
Cheers,
Ernest
Blue
Re: Teechart Pro 2011 XE2 installs only Standard
Post by Blue » Fri Oct 07, 2011 9:07 am
DCLTQRxx.bpl
DCLTeeProxx.bpl
DCLTGLxx.bpl
Seems to be missing !
Blue
Post by Blue » Fri Oct 07, 2011 1:34 pm
Both Delphi XE and Delphi XE2 are installed on the same Windows 7 x64 system.
When trying to compile the sources in Delph XE2 results in the error message
Tee916.dpk(1)
Tee916.dpk(33): E2202 Required package 'rtl' not found
Failed
(seems to be an old problem with the Delphi XE installer. Search this board for more information.)
Compiling with TeeRecompiler (as Administrator) doesn't work either. It looks like it uses the Delphi XE as default, resuliting in a '..\Compiled\Delphi15\' directory with *.bpl files. The result was that there is now that TeeChart Pro is back in Delphi XE.
Post by Yeray » Fri Oct 07, 2011 2:34 pm
Hello Blue,
Are you using the TeeChart v2011.04 PreRelease Source Code version or the TeeChart v2011.03 Source Code version?
Note that the v2011.04 Pre Release Source Code version is the first to support XE2.
Blue
Post by Blue » Fri Oct 07, 2011 2:50 pm
We use the v2011.04 Pre Release Source Code version that comes with the TeeChart Pro 2011 XE2 install as downloaded from your site.
Post by Yeray » Fri Oct 07, 2011 3:18 pm
Hello Blue,
It's strange.
- Are you using the Rad Studio XE2 with update 1? (Here I have v16.0.4276.44006)
- Did the source code installer finished without errors?
- What options do you select in TeeRecompile tool?
- Can you also try the last TeeRecompile version in this thread?
Blue
Post by Blue » Mon Oct 10, 2011 10:59 am
Yes.
Yes.
All. Works only when runned as Administrator.
Yes, did that already.
See the result log;
TeeChart Pro
Compilation started: 10-10-2011 12:54:58
RAD 2011.Win32 v15 (RAD XE v8 Enterprise)
Tee915
Embarcadero Delphi for Win32 compiler version 22.0
Copyright (c) 1983,2010 Embarcadero Technologies, Inc.
87536 lines, 1.51 seconds, 802856 bytes code, 9432 bytes data.
TeeUI915
58721 lines, 2.23 seconds, 427828 bytes code, 1008 bytes data.
TeeDB915
7322 lines, 0.30 seconds, 57364 bytes code, 184 bytes data.
TeePro915
TeePro915.dpk(224) Warning: W1033 Unit 'TeeSubChartEditor' implicitly imported into package 'TeePro915'
157603 lines, 5.33 seconds, 1089032 bytes code, 6180 bytes data.
TeeGL915
13829 lines, 0.22 seconds, 113968 bytes code, 2964 bytes data.
TeeImage915
18960 lines, 0.66 seconds, 237396 bytes code, 11224 bytes data.
TeeWorld915
2101 lines, 0.30 seconds, 14396 bytes code, 168 bytes data.
TeeLanguage915
76057 lines, 1.06 seconds, 3296832 bytes code, 3408 bytes data.
DclTee915
4799 lines, 1.47 seconds, 50292 bytes code, 220 bytes data.
DclTeePro915
10317 lines, 0.55 seconds, 96624 bytes code, 380 bytes data.
DclTeeProStd915
10314 lines, 0.25 seconds, 90044 bytes code, 364 bytes data.
TeeMaker115
78557 lines, 1.12 seconds, 732640 bytes code, 12716 bytes data.
DclTeeMaker115
724 lines, 0.22 seconds, 14268 bytes code, 104 bytes data.
Compilation started: 10-10-2011 12:55:17
TeeTree2D15Tee9
42743 lines, 0.41 seconds, 583956 bytes code, 1388 bytes data.
DclTree2D15Tee9
1288 lines, 0.69 seconds, 11268 bytes code, 140 bytes data.
OK. Time: 20s
RAD XE2.Win32 v16 (RAD XE v9 Enterprise)
EXCEPTION:
Cannot copy file: C:\Program Files (x86)\Steema Software\TeeChart Pro 2011 Full Source Code\Sources\FMXTee.Chart.ListBox.pas to C:\Program Files (x86)\Steema Software\TeeChart Pro 2011 Full Source Code\Sources\FMX\FMXTee.Chart.ListBox.pas
Error Code: 2 Description: Het systeem kan het opgegeven bestand niet vinden // systemm cannot find requested file
As you can see only the Delphi XE version is build.
Post by Yeray » Mon Oct 10, 2011 12:12 pm
Hello Blue,
Blue wrote:- What options do you select in TeeRecompile tool?
I'm a little bit confused about the "as administrator" option you use to run TeeRecompile. What difference do you experience between using and not using it?
Also note that TeeRecompile tool shows a different list of IDEs depending on those you have installed in your system. I assume you have both Rad XE and RadXE2, you select both IDEs and only the first one is finishing without problems. Am I right?
Blue
Post by Blue » Mon Oct 10, 2011 1:05 pm
Not using the Administration option would result in;
TeeChart Pro
Compilation started: 10-10-2011 14:58:17
EXCEPTION:
Error deleting file: C:\Program Files (x86)\Steema Software\TeeChart Pro 2011 Full Source Code\Sources\Compiled\Delphi15\Lib\ArrowCha.dcu
Error Code: 5 Description: Toegang geweigerd // No access allowed
All the installed enviroments are checked;
RAD 2011
RAD XE2 Win32
RAD XE2 Win64
RAD XE2 MacOSX
RAD XE2 iOS
Blue
Post by Blue » Mon Oct 10, 2011 1:07 pm
Yes only the first one is finished. Compiling stops at RAD XE2 Win32.
Post by Yeray » Thu Oct 13, 2011 3:06 pm
Hello Blue,
We haven't forgotten you. We will probably publish a new PreRelease version as soon as we'll solve some problems we've identified.
Blue
Post by Blue » Fri Oct 14, 2011 8:20 am
Thank you, you are my heroes !
