Delphi XE2 prerelease - shadow of bar series look strange
marder
Post by marder » Fri Nov 18, 2011 4:05 pm
Hi.
I am using the Delphi XE2 prerelease of TreeChart Pro V2011 and just wanted to report that the shadow of a bar series is looking quite strange with this version.
Before:
Now:
Will the shadow be corrected in the official release version?
best regards.
Re: Delphi XE2 prerelease - shadow of bar series look strange
Post by Yeray » Mon Nov 21, 2011 2:58 pm
Hello Marder,
marder wrote:I am using the Delphi XE2 prerelease of TreeChart Pro V2011 and just wanted to report that the shadow of a bar series is looking quite strange with this version.
You are right, it worked fine in v2011.03 but in v2011.04. I've added it to the defect list to be fixed asap (TV52015903).
PS: I assume you meant "pie series" where you said "bar series", according to the pictures. :P
marder
Post by marder » Mon Nov 21, 2011 4:23 pm
Hello Yeray.
Yes, I meant "pie" :wink:
Could you please send me a fixed prerelease version when you have fixed this issue?
This would be great!
Best regards.
Post by Narcís » Tue Nov 22, 2011 10:17 am
Hi marder,
I have logged your request in the issue description.
marder
Post by marder » Thu Nov 08, 2012 8:48 am
Hi.
I wonder if there might be a fix for this issue in the official release of the upcoming V2012.07?
Best regards.
Post by Narcís » Thu Nov 08, 2012 10:40 am
Hi marder,
Build 2012.07.121105, the version we published yesterday, is the official 2012.07 release.
The bug hasn't been fixed yet but we found where the problem is. Since you are a source code customer you may want to try implementing TTeeCanvas3D.SmoothShadow at TeCanvas.pas like this:
procedure TTeeCanvas3D.SmoothShadow(Shadow:TTeeShadow; const Rect:TRect;
                             Ellipse:Boolean; RoundSize:Integer;
                             const P:Array of TPoint;
                             DonutPercent:Integer=0;
                             const Z:Double=0);
  if Shadow.Smooth and (not Metafiling) {$IFNDEF FMX}and Assigned(FBitmap){$ENDIF} then
     Shadow.InternalDrawSmooth(Self,
                               CalcRect3D(Rect,Round(Z)),
                               Ellipse,RoundSize,P,DonutPercent)
     inherited;
That's similar to how it was implemented before introducing the bug. Now we will investigate the reason for this change and try to find a permanent fix for the issue.
marder
Post by marder » Fri Nov 09, 2012 12:42 pm
Hi Narcis.
I downloaded final version V2012.07.
After installation I run "TeeRecompile.exe" and get the following error:
TeeChart Pro
Compilation started: 09.11.12 13:39:22
RAD XE2.Win32 v16 Architect (RAD XE v9 Architect)
EXCEPTION:
Text: unit TeeChart not found in TeeChart.pas
How can I get it to run?
Best regards.
Post by Yeray » Fri Nov 09, 2012 12:45 pm
Hi Marder,
Please, remove the TeeChart.pas file and try it again.
marder
Post by marder » Fri Nov 09, 2012 2:51 pm
Thank you that worked.
The shadow is again drawn as expected.
Please let me know when there is a new maintenance release including this fix.
Until then I will use the customization.
Best regards.
Post by Narcís » Tue Nov 20, 2012 7:30 am
Hi marder,
As an update, TV52015903 has been fixed for the next maintenance release. The fix is at the TPieSeries.DrawAllValues method, in Series.pas:
  if FShadow.Visible then
     FShadow.DrawEllipse(ParentChart.Canvas,
                         ParentChart.Canvas.CalcRect3D(CircleRect,tmpShadowZ),
                         tmpShadowZ,DonutPercent);
You should remove the change I suggested in TeCanvas.pas and change FShadow.DrawEllipse call as shown above.
marder
Post by marder » Fri Nov 23, 2012 5:03 pm
Dear Narcis.
Thank you!
I will give this a try soon.
Best regards
marder
Post by marder » Mon Nov 26, 2012 3:09 pm
Dear Narcis.
The new fix seems to work correctly.
Thanks for your help!
Best regards.
Post by Narcís » Mon Nov 26, 2012 3:20 pm
Dear Marder,
Thanks for your feedback, I'm glad to hear that.
