V 2011 AV on Pointer.Style = psVisual
Bert Kreisel
Post by Bert Kreisel » Thu Jan 05, 2012 7:54 am
1. I installed TeeChart2011Delphi2010.
2. I run TeeChartOffice.
3. Open Edit -> Properties
4. Add Serie Line with Points
5. Select Point -> Style tab
6. Choose Style "Visual" in ComboBox -> AV in Tee914.bpl at adress FFFFFFFC.
The same Error is in Tee9New.exe:
1. All features -> Basic feature
2. Show the chart editor
3. Add Serie Line with Points
4. Select Point -> Style tab
5. Choose Style "Visual" in ComboBox
6. Select tap Data Source -> AV in Tee914.bpl at adress FFFFFFFC.
Bert Kreisel
Re: V 2011 AV on Pointer.Style = psVisual
Post by Narcís » Thu Jan 05, 2012 8:36 am
Hi Bert,
Thanks for reporting. I could reproduce the issue here and added it (TV52015991) to the bug list to be fixed. "visuals" style shouldn't be there. This is for selecting a TeeMaker demo object but this feature is not complete so shouldn't be available for now.
Bert Kreisel
Post by Bert Kreisel » Wed Jun 20, 2012 6:58 am
Hi Narcís,
In TeeChart 2012.06.120613 for Delphi 2010 the bug TV52015991 is still not fixed.
Bert Kreisel
Post by Sandra » Wed Jun 20, 2012 9:15 am
Hello Bert,
The bugs are sorted by severity and if there are bugs with higher severity than other, these should be solved before. Moreover, if we have many bugs with high severity is possible some bugs aren't fixed, for new releases. For this reason, the bug with number (TV52015991)isn't fixed for last maintenance release. But inform you that it is in the bug list report with a high severity and it will be treated for next maintenance releases.
Thank,
Bert Kreisel
Post by Bert Kreisel » Thu Oct 16, 2014 12:50 pm
In TeeChart 2014.12.140923 for Delphi XE5 the bug TV52015991 is still not fixed.
Bert Kreisel
Post by Yeray » Thu Oct 16, 2014 1:12 pm
Hi Bert,
You can follow the ticket here:
http://bugs.teechart.net/show_bug.cgi?id=277
