Can not compile Features demo project
jls
Post by jls » Mon Apr 16, 2012 10:14 am
unit OpenGL2;
[DCC Error] OpenGL2.pas(3642): E2242 'OpenGL2' is not the name of a unit
any reason?
Re: Can not compile Features demo project
Post by Yeray » Mon Apr 16, 2012 10:24 am
What IDE are you using? If you are using XE2, note you may need to add "VCLTee" namespace:
http://www.teechart.net/support/viewtop ... 293#p57293
jls
Post by jls » Mon Apr 16, 2012 11:28 am
it was in the project scope, added it as a global scope and it got new error, now in
unit Base;
ncAntiAlias : Chart1.Canvas:=TAntiAliasCanvas.Create;
[DCC Error] Base.pas(72): E2010 Incompatible types: 'TCanvas3D' and 'TAntiAliasCanvas'
Post by Narcís » Thu Apr 19, 2012 9:49 am
Hi jls,
So I assume you are using Delphi XE2. Do you have Update 4 installed on it? Are you using TeeChart Pro 2012.05 VCL? Please bear in mind that v2012.05 requires XE2 update 4 installed. Could you also check that latest TeeChart version search paths are on *top* of the search path list at Tools -> Options -> Environment Options -> Delphi Options -> Library?
