Problem with changing font size on marks with TPointSeries
Johan Ingemansson
Post by Johan Ingemansson » Sun Sep 19, 2004 6:39 pm
When I use the TPointSeries and I want to change the font size, this works fine. But I have written my on anti-overlapping algorithm for the markers, when I use this algorithm(i.e change the marker positions) the font size doesn´t change. The marker frame however changes but the font size remains as default. Does anyone know how to solve this problem?
Johan Ingmemansson
Post by Pep » Mon Sep 20, 2004 4:44 pm
Hi Johan,
yes, you're correct, it's a bug. We'll try to fix it for the next maintenance releases.
For the moment I've not found a workaround, If I know anyone I'll let you know.
Johan Ingemansson
Post by Johan Ingemansson » Tue Sep 21, 2004 6:20 am
This can be a real problem for me, because I have a deadline in less then two weeks, and this functionality is crucial the project. I have ordered the source code, do you know if it´s possible to fix the bug there? When will the next update be released from you?
Johan Ingemansson
