Tee*9170.bpl for XE3 beta needed
Wafios
Post by Wafios » Fri Jul 06, 2012 10:36 am
I currently test the beta of XE3 but there is missing the tee9170.bpl.
The sources of Tee-Standard isn't distributed. Can I download the missing package somewhere?
Re: Tee*9170.bpl for XE3 beta needed
Post by Narcís » Fri Jul 06, 2012 10:38 am
Hi Wafios,
I'm afraid not. Steema generally doesn't support an IDE until the final version comes out. The TeeChart versions shipped with Embarcadero products are under their control.
Wafios
Post by Wafios » Fri Jul 06, 2012 12:33 pm
Do I really need the bpls of the standard version if I use the pro version?
Until now I was not able to remove the missing bpl out of the linker...
Post by Narcís » Mon Jul 09, 2012 9:17 am
Hi Wafios,
No, you don't need them. Moreover, referencing them will cause version conflicts with the Pro version.
You should make sure no Std version packages and paths are being referenced from your IDE and also make sure the Pro version search paths are on top of the list so they are the version being used.
Wafios
Post by Wafios » Tue Jul 10, 2012 2:25 pm
I thought I already eliminated all references to standard TeeChart, but it seems to be still missed...
The support of Embarcadero said, that the package was not delivered yet from you!
So who is my contact to this package?!?
Post by Yeray » Wed Jul 11, 2012 8:24 am
Hi Wafios,
We don't publish the TeeChart Standard packages embedded in an IDE, that's Embarcadero's responsibility.
And, when an IDE is in a pre-release stage, it is usually substantially modified through the different betas, release candidates, etc, so the packages embedded in it also have to be modified during the process.
Steema doesn't support IDEs in pre-release stages.
