ColorEachPoint and Gradient?
Jim Green
Post by Jim Green » Mon Aug 20, 2012 8:33 pm
Hello, is it possible to use BarSeries.ColorEachPoint and have a gradient?
Re: ColorEachPoint and Gradient?
Post by Yeray » Tue Aug 21, 2012 12:33 pm
Yes, you can. Ie:
    FillSampleValues;
    ColorEachPoint:=true;
    BarStyle:=bsRectGradient;
Jim Green
Post by Jim Green » Tue Aug 21, 2012 2:34 pm
Yeray, I should have mentioned that I'm specifying the colors - positive values in green and negative in red, but a gradient version of each color. So I have:
      if series.ColorEachPoint then
        if y < y0 then
          color := clRed
          color := clGreen
        color := clDefault;
      series.AddXY(x, y, '', color);
Where would you supply the 2nd color for the gradient?
Jim
Post by Yeray » Wed Aug 22, 2012 7:36 am
Hi Jim,
Jim Green wrote:Where would you supply the 2nd color for the gradient?
You should set the series' Gradient.StartColor property.
However this is a color for the whole series. If you want to set a different StartColor for each point, you could use the OnGetPointerStyle/OnGetBarStyle event to change that color each time a point/bar is going to be drawn.
Procedure TForm1.GetBarStyle(Sender:TCustomBarSeries; ValueIndex:Integer; var TheBarStyle:TBarStyle);
  Sender.Gradient.StartColor:=ApplyBright(Sender.ValueColor[ValueIndex], 128);
