Cannot build a VCL project for a 64-bit Windows Target
PRM
Post by PRM » Mon Dec 17, 2012 8:40 am
I cannot build a VCL project using TeeChart for a 64-bit Windows Target. 32-bit Windows Target compilation is OK.
To simplify the problem, if I create a new VCL Forms application using Delphi XE3, add TChart and TeeCommander objects to Unit 1 and then build this project for a 64-bit Windows target I get the following error message:
[dcc64 Fatal Error] Unit1.pas(8): F2051 Unit VCLTee.TeeComma was compiled with a different version of VCLTee.Chart.TCustomChart
My 64-bit Windows Library path includes:
C:\Program Files (x86)\Steema Software\TeeChart 2012 for RAD XE3\Delphi17.win64\Lib
Re: Cannot build a VCL project for a 64-bit Windows Target
Post by Yeray » Mon Dec 17, 2012 3:20 pm
Check your IDE doesn't have references to old TeeChart installations in the packages list or in the library and search path lists.
PRM
Post by PRM » Mon Dec 17, 2012 10:25 pm
Greetings Yeray,
Thank you for your reply. On further investigation I found that the win64 TeeChart FMX and VCL files provided with RAD Studio had not been moved to the Backup_TeeChart folder. The win32 files had been moved to backup. Once I removed these files from the RAD Studio\lib\win64 I could compile the program correctly for a 64-bit Windows Target.
Best regards,
Peter.
