OnClick event for arrow in TArrowSeries
Rolf Fankhauser
Post by Rolf Fankhauser » Thu Dec 20, 2012 3:37 pm
Hi all,
Is there an event for clicking on (or moving over) an arrow in a TArrowSeries? I can only click on the start point of the arrow but not on the arrow. I would like to implement that the cursor changes to crHandPoint if it is over an arrow and to show some data in a popup window if the arrow is clicked. Possible?
Thanks in advance for any help!
Best regards,
Rolf
Rolf Fankhauser
Re: OnClick event for arrow in TArrowSeries
Post by Rolf Fankhauser » Thu Dec 20, 2012 6:26 pm
It seems to be a bug in an older version. In C++Builder XE2 with TChart Std v2011.03.32815 it's working! I used OnMouseEnter and OnMouseLeave to set the cursor style.
But when I click the button of the popup window to close it, a white zoom frame is drawn from the point where I clicked the arrow to the point where I closed the popup window. How can I prevent this (the drawing of the zoom frame)? I have to click again to get rid of the zoom frame but then the chart is zoomed what wasn't intended.
A possible workaround: I could deactivate zooming and add a button to enable zooming.
Best regards, Rolf
Post by Yeray » Fri Dec 21, 2012 3:02 pm
Hi Rolf,
Rolf Fankhauser wrote:But when I click the button of the popup window to close it, a white zoom frame is drawn from the point where I clicked the arrow to the point where I closed the popup window. How can I prevent this (the drawing of the zoom frame)? I have to click again to get rid of the zoom frame but then the chart is zoomed what wasn't intended.
I've tried the following code but I don't see this effect:
uses ArrowCha;
  with Chart1.AddSeries(TArrowSeries) as TArrowSeries do
    FillSampleValues(5);
    ArrowWidth:=32;
    ArrowHeight:=24;
procedure TForm1.Chart1ClickSeries(Sender: TCustomChart;
  Series: TChartSeries; ValueIndex: Integer; Button: TMouseButton;
  with TForm.Create(Self) do
    Width:=100;
    Height:=100;
    Left:=Form1.Left+Chart1.Left+X-50;
    Top:=Form1.Top+Chart1.Top+Y;
    ShowModal;
Could you please modify the code above or arrange a simple example project we can run as-is to reproduce the problem here?
Rolf Fankhauser wrote:A possible workaround: I could deactivate zooming and add a button to enable zooming.
It sounds as a possible workaround. However, if we can reproduce the problem here we'll study if disabling the zooming feature at OnMouseEnter or some other event solves the problem too.
