Hidden close button
HarriR
Hidden close button
Post by HarriR » Fri Oct 01, 2004 9:53 am
Hi!
Is the button named "BClose" inside TeePrevi.pas use anywhere? It seems to show up mostly as hidden, but as it is placed on the separate panel, this panel (Panel3) will then cover adjacent "Print" button inside dialog window.
I made the Panel3 invisible and everything seems to work - but still, is it safe to do this?
Harri
Post by Pep » Mon Oct 04, 2004 7:26 am
Hi Harri,
It's used in the ChartPreviewer component, but you're correct, I see what you mean. I think it should be placed at the same panel of the "Setup" and "Print" buttons. I've put down our defect list to be reviewed for the next maintenance releases.
