Cursor x and y values
sunman4008
Post by sunman4008 » Tue Apr 09, 2013 2:09 pm
How do I show a crosshair cursor which displays the X-axis and the Y-axis values?
-Mike
Re: Cursor x and y values
Post by Yeray » Wed Apr 10, 2013 10:27 am
Hi Mike,
Looks like this, isn't it?
http://www.teechart.net/support/viewtop ... f=3&t=6964
sunman4008
Post by sunman4008 » Thu Apr 18, 2013 12:06 am
What is ChartTool2 in the example? What does it mean by Annotion Tool?
Also...the picture are not shown.
-Mike
Post by Yeray » Thu Apr 18, 2013 9:15 am
Hi Mike,
Sorry if it wasn't clear enough.
I've made a more complete example from it. You only need to add a Chart to the form at design time and the following code:
uses {...} Series, TeeTools;
  private
    { Private declarations }
    procedure cursorToolChange(Sender: TCursorTool; x, y: Integer;
      const XValue, YValue: Double; Series: TChartSeries; ValueIndex: Integer);
var cursorTool: TCursorTool;
    annotatTool: TAnnotationTool;
  Chart1.View3D:=false;
  Chart1.AddSeries(TPointSeries).FillSampleValues;
  cursorTool:=Chart1.Tools.Add(TCursorTool) as TCursorTool;
  cursorTool.OnChange:=cursorToolChange;
  annotatTool:=Chart1.Tools.Add(TAnnotationTool) as TAnnotationTool;
  annotatTool.PositionUnits := muPixels;
  annotatTool.Shape.CustomPosition := true;
  Chart1.Draw;
  annotatTool.Shape.Top := Chart1.Axes.Bottom.PosAxis + 20;
procedure TForm1.cursorToolChange(Sender: TCursorTool; x, y: Integer;
  annotatTool.Text := floattostr(XValue);
  Chart1.Draw;
  annotatTool.Shape.Left := Chart1.Axes.Bottom.CalcXPosValue(XValue) - (annotatTool.Shape.Width div 2);
  Caption := 'X: ' + floattostr(XValue) + '    Y: ' + floattostr(YValue);
Don't hesitate to let us know if you find any problem when adapting it to your specific needs.
