How to delete a fibonacci object
sswang
Post by sswang » Mon May 13, 2013 9:21 am
There are multiple TFibonacciTool objects on my chart.
Is there a way to perform delete operation by clicking one of them? thanks.
Re: How to delete a fibonacci object
Post by Yeray » Mon May 13, 2013 11:45 am
At the moment there isn't a clicked function for the TFibonacciTool. I've added it to the wish list to be implemented in future releases (TV52016571).
In the meanwhile you could try to do it manually.
Here it is an example that works for a series with multiple TFibonacciTools. However in this example I'm only calculating if the trending line is being clicked, not for the levels. For the levels you'll have to loop the levels, calculate the lines where they are drawn and check them as I do for the trend line.
var MDown: TPoint;
var i: Integer;
  Chart1.View3D:=false;
  Chart1.AddSeries(TCandleSeries).FillSampleValues(35);
  for i:=0 to 2 do
    with Chart1.Tools.Add(TFibonacciTool) as TFibonacciTool do
      StartX:=(Chart1[0] as TCandleSeries).DateValues[i*10];
      StartY:=(Chart1[0] as TCandleSeries).CloseValues[i*10];
      EndX:=(Chart1[0] as TCandleSeries).DateValues[(i+1)*10];
      EndY:=(Chart1[0] as TCandleSeries).CloseValues[(i+1)*10];
      DrawStyle:=fsRetracement;
  MDown.X:=X;
  MDown.Y:=Y;
procedure TForm1.Chart1Click(Sender: TObject);
var i: Integer;
  for i:=0 to Chart1.Tools.Count-1 do
  if Chart1.Tools[i] is TFibonacciTool then
  with Chart1.Tools[i] as TFibonacciTool do
    if ((DrawStyle=fsFan) or (DrawStyle=fsArc)) then
      if PointInLine(MDown, Chart1.Axes.Bottom.CalcPosValue(StartX), Chart1.Axes.Left.CalcPosValue(StartY),
                     Chart1.Axes.Bottom.CalcPosValue(EndX), Chart1.Axes.Left.CalcPosValue(EndY)) then
        Active:=false;
        exit;
      if DrawStyle=fsFan then
      end
      else //DrawStyle=fsArc
    end
    begin //DrawStyle=fsRetracement
                     Chart1.Axes.Bottom.CalcPosValue(EndX), Chart1.Axes.Left.CalcPosValue(StartY)) or
         PointInLine(MDown, Chart1.Axes.Bottom.CalcPosValue(StartX), Chart1.Axes.Left.CalcPosValue(EndY),
        Active:=false;
        exit;
sswang
Post by sswang » Tue May 14, 2013 3:39 am
Nice! Thanks.
