Restricting zooming and scrolling
Metman
Post by Metman » Wed May 22, 2013 4:15 pm
Whilst I would like to allow my user to be able to zoom and scroll within a series of a chart, is there anyway that I can restrict a user from scrolling or zooming beyond/outside the extents of a series maximum and minimum xvalues??
I know this must be obvious but I just wondered if you could do it without writing a lot of additional code.
Bruce.
Re: Restricting zooming and scrolling
Post by Yeray » Thu May 23, 2013 10:00 am
Hi Bruce,
You can use the OnZoom and OnScroll events to limit it. Ie:
uses Series;
  Chart1.View3D:=false;
  Chart1.AddSeries(TPointSeries).FillSampleValues;
  if Chart1.Axes.Bottom.Maximum-Chart1.Axes.Bottom.Minimum<5 then
    Chart1.Zoom.Allow:=false;
However, this would disable the zoom and you won't be able to unzoom.
An alternative would be to use the zoom history. When the condition is reached you can restore the last axes values. This way you won't zoom more than desired:
  Chart1.Zoom.History:=true;
    with Chart1.Zoom.AxesHistory.Items[Chart1.Zoom.AxesHistory.Count-1] do
      Chart1.Axes.Bottom.SetMinMax(AxesMinMax[6], AxesMinMax[7]);
Or you can do it manually, if you want to avoid saving the history and directly jump to the initial state when you unzoom after several zooms:
uses Series;
var bottomMin, bottomMax: Double;
  bottomMin:=-1;
  bottomMax:=-1;
    if (bottomMin<>-1) and (bottomMax<>-1) then
      Chart1.Axes.Bottom.SetMinMax(bottomMin, bottomMax)
      Chart1.Axes.Bottom.SetMinMax(Chart1.Axes.Bottom.Minimum, Chart1.Axes.Bottom.Minimum+5);
  bottomMin:=Chart1.Axes.Bottom.Minimum;
  bottomMax:=Chart1.Axes.Bottom.Maximum;
Metman
Post by Metman » Thu May 23, 2013 10:16 am
Thanks Yeray I'll give that a go!
