TeeGDIPlus error and Cbuilder XE4
anauta2014
Post by anauta2014 » Sat Jun 15, 2013 3:34 pm
Today I've installed fresh version of the CBuilder XE4 and the last TeeChartPro2013 from binary.
The simple application could not be compiled due to this old issue.
I found for me the simple solution:
1.I've changed the 3D->Render to the GDI
2. The #include <Winapi.GDIPAPI.hpp> // Pascal unit - I've deleted this line from my source code.
After that the application was compiled fine.
Conclusion: current version of the TeeChartPro2013 can't be used for CBuilder XE3-XE4 (or may be XE-XE2 also, I did not check) with Render = GDI+
With best regards
Vladimir
Re: TeeGDIPlus error and Cbuilder XE4
Post by Yeray » Tue Jun 18, 2013 3:16 pm
Hello Vladimir,
Some other customers have found it. We are working on it for the next maintenance release.
Post by Yeray » Fri Jun 21, 2013 2:14 pm
Hi Vladimir,
As you can read here, I've prepared a new environment with a fresh install of Windows 7 x64 (Ultimate N) with Service Pack 1, C++Builder XE4 with Update1 and TeeChart Pro v2013.08 (final binary, not beta), everything with the default settings, and everything seems to work fine in it.
anauta2014
Post by anauta2014 » Mon Jun 24, 2013 5:43 am
Hi, Yeray
I am using windows8-64 on two PCs. Both installation of the TeeChart2013 have the same problem with TeeGDIPlus headers.
For this reason I have to disable GDI+ renedering and work without.
I've seen this issue for XE2-XE3 CBuilder also.
With best regards
Vladimir
Post by Yeray » Thu Jun 27, 2013 11:17 am
Hi Vladimir,
New tests with Win8 seem to confirm this has to be caused by some confusion in your IDE.
