Using a Color Band to select a range of bars
TestAlways
Post by TestAlways » Fri Apr 25, 2014 7:20 pm
In the demo using the link, I can click and drag the mouse left or right and it will normally highlight a x-range of the grid -- a color band highlights the selected items.
1. But.... sometimes it doesn't work (this it is highlighted in the MP4 video in the download). I can click and drag and the color band's start and end value seem to be the same. It seems that this occurs if I click on the very left side of a bar.
http://www.TBInc.com/misc/SelectionPoint3a.zip
I can't figure out how to fix this behavior.
2. Also, when the band is drawn, it is drawn from the left edge of the bar. How can I make the band start in the middle of the bar?
Thank you,
Ed Dressel
Re: Using a Color Band to select a range of bars
Post by Yeray » Mon Apr 28, 2014 10:44 am
Hi Ed,
TestAlways wrote:1. But.... sometimes it doesn't work (this it is highlighted in the MP4 video in the download). I can click and drag and the color band's start and end value seem to be the same. It seems that this occurs if I click on the very left side of a bar.
This part is the easy one. Some events seem to be interfering here. You can fix it disabling the AllowDrag property on all the dependant tools:
  cbHighlight.StartLine.AllowDrag:=false;
  cbHighlight.EndLine.AllowDrag:=false;
  cbHighlight.AllowDrag:=false;
TestAlways wrote:2. Also, when the band is drawn, it is drawn from the left edge of the bar. How can I make the band start in the middle of the bar?
This will be more difficult. This means to change how the TColorBandTool is being drawn and I haven't found a way to override the needed functions so I can only think on modifying the TColorBandTool Drawing method on TeeChart sources or to skip using this tool and draw what you want in the OnBeforeDrawSeries event.
