Rose Series Data Angles
esbglenn
Post by esbglenn » Sat Jun 14, 2014 11:43 am
I have the following Data (that has been generated from a Database) in a Rose Series:
And it results in:
Though the AngleValues have equal increments, the chart seems to leave gaps - for example 0th value (red) appears fine but the 1th (not really 1st I suppose) value (green) doesn't occur next to it with the 2th value (yellow) overwriting it.
I am not doing anything too fancy:
          Chart2.RemoveAllSeries;
          Chart2.Title.Text.Clear;
          Angle := 360 / (CurrProjectThemeList.Count * 3);
          Chart2.BottomAxis.Increment := Angle * 3;
          Chart2.LeftAxis.Automatic := False;
          Chart2.LeftAxis.Minimum := 0;
          Chart2.LeftAxis.Maximum := 5;
          Chart2.LeftAxis.Increment := 1;
          RoseSeries := TFRSRose.Create (Chart2);
          RoseSeries.OnGetCircleLabel := CircleThemeLabels;
          for I := 0 to CurrProjectThemeList.Count - 1 do
               Ans := CurrProjectThemes [CurrProjectThemeList [I].Key];
               if Ans.Count [1] > 0 then
                    X := Ans.Totals [1] / Ans.Count [1]
                    X := 0;
               RoseSeries.AddPolar (Angle * (I * 3), X, '', clRed);
               if Ans.Count [2] > 0 then
                    X := Ans.Totals [2] / Ans.Count [2]
                    X := 0;
               RoseSeries.AddPolar (Angle * (I * 3 + 1), X, '', clGreen);
               if Ans.Count [3] > 0 then
                    X := Ans.Totals [3] / Ans.Count [3]
                    X := 0;
               RoseSeries.AddPolar (Angle * (I * 3 + 2), X, '', clYellow);
          Chart2.AddSeries (RoseSeries);
          RoseSeries.Pointer.Visible := False;
Any thoughts on what I am doing wrong?
esbglenn
Re: Rose Series Data Angles
Post by esbglenn » Sat Jun 14, 2014 2:02 pm
Basically I am after each section to be the same angle width but a different radius.
Post by Yeray » Mon Jun 16, 2014 8:16 am
Try setting the minimum and maximum of the Rose series Horiz&Vert axes. Ie:
  RoseSeries.GetVertAxis.SetMinMax(0, RoseSeries.RadiusValues.MaxValue);
  RoseSeries.GetHorizAxis.SetMinMax(0, RoseSeries.RadiusValues.MaxValue);
esbglenn
Post by esbglenn » Mon Jun 16, 2014 8:29 am
Excellent - many thanks for that!
