Chart custom graphics drawing
PoLabs
Post by PoLabs » Wed Jan 14, 2015 4:30 pm
I am doing some custom drawing on my chart control in connection with mouse movements. In other words, whenever I move mouse I am drawing some graphics on my chart.
Right now I am handling chart's OnBeforeDrawSeries and OnMouseMove.
eg. (just an example to show my apporach):
procedure xxx.OnMouseMove(Sender: TObject; Shift: TShiftState; X, Y: Integer);
  LastPt.X := x;
  LastPt.Y := y;
  Chart.Repaint;
procedure xxx.OnBeforeDrawSeries(Sender: TObject);
  Chart.Canvas.TextOut(LastPt.x, LastPt.Y, 'Some text');
At first look this method seems to be fine but it looks like it takes some time to preocess Chart.Repain and all custom graphics seems to be drawing quite slow. I checked out my methods and measured time to process and everythings looks reasonable (<1us).
I am not drawing on canvas directly in OnMouseMove event because graphics gets messed up if Chart.Repaint is called from any other method. Therefore I just execute Chart.Repaint to start events such as BeforeDrawSeries and AfterDrawGraph and do drawing there.
Is there any better approach to do that? What about declaring new class derived from Tchart and use some protected methods? Any suggestion?
Thank you in advance.
Kind regards.
Re: Chart custom graphics drawing
Post by Yeray » Thu Jan 15, 2015 9:36 am
This seems to work fine for me here:
uses Series;
var LastPt: TPoint;
  Chart1.AddSeries(TBarSeries).FillSampleValues();
  Y: Integer);
  LastPt.X := x;
  LastPt.Y := y;
  Chart1.Repaint;
procedure TForm1.Chart1BeforeDrawSeries(Sender: TObject);
  Chart1.Canvas.TextOut(LastPt.x, LastPt.Y, 'Some text');
This way you are redrawing all the chart each time the mouse is moved. This is the easiest way to go but it may be slow if you have many points in your chart needing some time for each repaint.
PoLabs
Post by PoLabs » Thu Jan 15, 2015 9:52 am
Yeah sure. I totaly forgot that all series are repainted too. I have up to 16 series with up to 4000 samples. So although my custom drawing is super fast it will always take some time to paint all 16 series. It makes sense.
Thanks for the hint and test of my code.
PoLabs
Post by PoLabs » Thu Jan 15, 2015 10:23 am
Is there any performance difference in calling chart.Repaint or Chart.Invalidate? What is the difference between them chart implementation wise?
Post by Yeray » Thu Jan 15, 2015 10:40 am
PoLabs wrote:Is there any performance difference in calling chart.Repaint or Chart.Invalidate? What is the difference between them chart implementation wise?
The Repiant method ends calling Invalidate so there isn't much difference between them.
