EInvalidOperation with TMarksTipTool and TSubChartTool
Eic
Post by Eic » Tue Oct 25, 2016 1:50 pm
I made this simple code to reproduce a bug :
void __fastcall TscrTestGraphe::Button2Click(TObject *Sender)
	TChart * Chart1 = new TChart(this);
	Chart1->Parent = this;
	Chart1->Align = alClient;
	TSubChartTool *SubChart1 = new TSubChartTool(NULL);
	Chart1->AddSeries(new TPointSeries(Chart1))->FillSampleValues();
	Chart1->Tools->Add(SubChart1);
	TChart * Chart2 = SubChart1->Charts->AddChart("MySubChart");
        // Chart2->Parent = _subChartTool->ParentChart;
	Chart2->AddSeries(new TPointSeries(Chart1))->FillSampleValues();
	TMarksTipTool *marksTipTool = new TMarksTipTool(Chart2);
	marksTipTool->OnGetText = OnGetMarksTipGetText;
	Chart2->Tools->Add(marksTipTool);
void __fastcall TscrTestGraphe::OnGetMarksTipGetText(TMarksTipTool* Sender, System::UnicodeString &Text)
	TChartSeries *serie = Sender->ParentChart->Series[0];
	int iValueIndex = serie->GetCursorValueIndex();  // <= Launch the exception
The objective is to use a TMarksTipTool on a SubChart.
At run time, calling the GetCursorValueIndex function generates the exception "Le projet TEST.exe a déclenché la classe d'exception EInvalidOperation avec le message 'Le contrôle 'MySubChart' n'a pas de fenêtre parente'."
If I enable the line :
I have no exception but the tip is not displayed.
How to view a Tip on a sub chart ?
Re: EInvalidOperation with TMarksTipTool and TSubChartTool
Post by Yeray » Fri Oct 28, 2016 9:51 am
I could reproduce the problem so I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1668
Eic
Post by Eic » Fri Oct 28, 2016 12:35 pm
Thank you for your reply.
Pending publication of the correction, what alternative do you propose to know the current index overflight in the event "OnGetText" ?
Post by Yeray » Mon Oct 31, 2016 1:39 pm
You could use the clicked function of the series and get the mouse position of the chart the subchart belongs to. Ie:
procedure TForm1.OnGetMarksTipGetText(Sender: TMarksTipTool; var Text: string);
var serie: TChartSeries;
    iValueIndex: Integer;
    i, j: Integer;
  serie := Sender.ParentChart.Series[0];
  //iValueIndex := serie.GetCursorValueIndex();  // <= Launch the exception
  for i:=0 to Chart1.Tools.Count-1 do
    if Chart1.Tools[i] is TSubChartTool then
       for j:=0 to (Chart1.Tools[i] as TSubChartTool).Charts.Count-1 do
          if (Chart1.Tools[i] as TSubChartTool).Charts[j].Chart = Sender.ParentChart then
            iValueIndex := serie.Clicked(Chart1.GetCursorPos); // <= Works fine
            //Caption:=IntToStr(iValueIndex);
            exit;
Eic
Post by Eic » Thu Nov 03, 2016 2:54 pm
It Works.
