2017.22 VCL standard installation error
Art
Post by Art » Fri Dec 01, 2017 12:26 am
I am getting this error in Teerecompile.exe after source code install:
TeeChart Standard
Compilation started: 11/30/2017 4:18:57 PM
Win32 v16 (Update 4 HotFix 1)
EXCEPTION:
Cannot copy file: C:\Program Files (x86)\Steema Software\Steema TeeChart Standard VCL FMX Source Code 2017.22\SourceStandard\FMXTee.Editor.TextShape.pas to C:\Program Files (x86)\Steema Software\Steema TeeChart Standard VCL FMX Source Code 2017.22\SourceStandard\FMX\FMXTee.Editor.TextShape.pas
Error Code: 2 Description: The system cannot find the file specified
The file is missing indeed. How can I fix it?
Re: 2017.22 VCL standard installation error
Post by Yeray » Fri Dec 01, 2017 7:40 am
FMXTee.Editor.TextShape.pas is in "SourceStandard\FMX_XE35" folder, I'm not sure why it searches it in "SourceStandard" folder.
I've just installed TeeChartVCLFMXStandardSOURCE-2017.22.exe and TeeRecompile compiled without errors for RAD Studio XE4.
Have you modified anything from the default settings in TeeRecompile?
If the same error keeps appearing, you can try to copy the .pas one folder up, into "SourceStandard" to see if TeeRecompile continues. You can repeat the operation if it searches more files at the wrong place.
If you still find problems with it don't hesitate to let us know and I'll try to search a machine with RAD Studio XE2 to try it with the same environment than you.
