Performance Issue with Grid Lines and PenStyle psDot
ags
Post by ags » Thu Dec 19, 2024 9:43 am
Hello Steema Support,
I am experiencing significant performance degradation when enabling minor grid lines in TChart. Here are the details:
- TChart Version: 2023.38.230607
- Delphi Version: Delphi 11
- Operating System: Windows 11 Enterprise
Description:
When I enable minor grid lines in a TChart, the chart's rendering performance drops significantly. This is an issue when we do realtime redraws on mousemove events (see example) and in general when redrawing multiple/big charts.
Steps to Reproduce:
1. Create a new VCL Forms Application in Delphi.
2. Add the code provided below
3. run the app in 64-bit, maximized (in full screen) (performance is the same in 32-bit, but that is not our usecase)
4. Move the mouse into the chart, and the last point in the fastlineseries will follow the movement of the mouse.
5. Use mouse button click to add points to the chart. The display of minor grid lines will be switched on/off every time you click to add a point.
6. Observe the performance degradation when the chart is rendered with minor grid lines visible and you move the mouse.
Sample Code:
uses
  VCLTee.Chart, VCLTee.TeEngine, VCLTee.Series;
  Chart1: TChart;
  FastLineSeries: TFastLineSeries;
procedure TForm1.AddFastLineSeriesToPlot;
  FastLineSeries := TFastLineSeries.Create(nil);
  FastLineSeries.XValues.Order := loNone;
  FastLineSeries.YValues.Order := loNone;
  FastLineSeries.LinePen.OwnerCriticalSection := nil; // single threaded
  FastLineSeries.LinePen.Style := psSolid;
  FastLineSeries.LinePen.Width := 5;
  FastLineSeries.Color := clRed;
  FastLineSeries.AutoRepaint := False;
  Chart1.AddSeries(FastLineSeries);
procedure TForm1.ShowHideMinorGrid;
  MinorGridVisible: Boolean;
  if FastLineSeries.XValues.Count > 0 then begin
    MinorGridVisible := Odd(FastLineSeries.XValues.Count);
    Chart1.BottomAxis.MinorGrid.Visible := MinorGridVisible;
    Chart1.LeftAxis.MinorGrid.Visible := MinorGridVisible;
procedure TForm1.AddPoint(MouseX, MouseY: Integer);
  X: Double;
  Y: Double;
  X := Chart1.BottomAxis.CalcPosPoint(MouseX);
  Y := Chart1.LeftAxis.CalcPosPoint(MouseY);
  FastLineSeries.AddXY(X, Y);
  FastLineSeries.Repaint;
procedure TForm1.MoveLastPoint(MouseX, MouseY : Integer);
  Index: Integer;
    Index := FastLineSeries.XValues.Count - 1;
    FastLineSeries.XValues[Index] := Chart1.BottomAxis.CalcPosPoint(MouseX);
    FastLineSeries.YValues[Index] := Chart1.LeftAxis.CalcPosPoint(MouseY);
procedure TForm1.Chart1MouseDown(Sender: TObject; Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
  AddPoint(X, Y);
  ShowHideMinorGrid;
procedure TForm1.Chart1MouseMove(Sender: TObject; Shift: TShiftState; X, Y: Integer);
  MoveLastPoint(X, Y);
  Chart1 := TChart.Create(Self);
  Chart1.Parent := Self;
  Chart1.Align := alClient;
  Chart1.View3D := False;
  Chart1.Legend.Visible := False;
  Chart1.ClipPoints := False;
  Chart1.Canvas.ReferenceCanvas.Pen.OwnerCriticalSection := nil; // single threaded
  Chart1.Axes.FastCalc := True;
  Chart1.BottomAxis.SetMinMax(0, 100);
  Chart1.LeftAxis.SetMinMax(0, 10);
  Chart1.OnMouseDown := Chart1MouseDown;
  Chart1.OnMouseMove := Chart1MouseMove;
  // major grid
  Chart1.BottomAxis.Grid.Visible := True;
  Chart1.BottomAxis.Grid.Style := psSolid;
  Chart1.BottomAxis.Grid.Width := 2;
  Chart1.BottomAxis.Grid.Color := clLtGray;
  Chart1.LeftAxis.Grid.Visible := True;
  Chart1.LeftAxis.Grid.Style := psSolid;
  Chart1.LeftAxis.Grid.Width := 2;
  Chart1.LeftAxis.Grid.Color := clLtGray;
  // minor grid
  Chart1.BottomAxis.MinorGrid.Visible := False;
  Chart1.BottomAxis.MinorGrid.Style := psDot;
  Chart1.BottomAxis.MinorGrid.Width := 1;
  Chart1.BottomAxis.MinorGrid.Color := clLtGray;
  Chart1.LeftAxis.MinorGrid.Visible := False;
  Chart1.LeftAxis.MinorGrid.Style := psDot;
  Chart1.LeftAxis.MinorGrid.Width := 1;
  Chart1.LeftAxis.MinorGrid.Color := clLtGray;
  AddPoint(10, 10);
I would appreciate any advice or solutions you can provide to improve the performance when minor grid lines are enabled.
Thank you,
Ags
Update:
After further investigation the cause of the performance issue is narrowed down to the PenStyle:
  Chart1.LeftAxis.MinorGrid.Style := psDot;   // is slow
  Chart1.LeftAxis.MinorGrid.Style := psSolid; // is fast
However that means that the performance issue is also observed if psDot is used for the major grid lines:
  Chart1.LeftAxis.Grid.Style := psDot; // is slow
Re: Performance Issue with Grid Lines and PenStyle psDot
Post by Yeray » Fri Dec 20, 2024 8:27 am
I'm afraid GDIPlus is slow at drawing dashed lines. However, moving to OpenGL may be a good option for you.
In that project, just add TeeGLCanvas to the uses clause and initialize the canvas at the end of your FormCreate:
  Chart1.Canvas:=TGLCanvas.Create;
ags
Post by ags » Wed Jan 22, 2025 12:44 pm
Thank you for the suggestion, the TGLCanvas does draw punctured gridlines faster.
Unfortunately the OpenGL canvas is not a seamless 1:1 replacement of the GDI+ version, and we have run into various small and big issues when testing with our app.
The minor issues are the placement of text and labels, eg the position of chart annotations is a bit different. If we should move to TGLCanvas, we would have to spend some time adjusting the position of the various elements to the changed layout.
The major issue that we have seen, is that something with the panning event handler seems to work in a different way and the code we have that draws an image with data that we decided were not suited for any of the existing series types, just fails in a very noticeable way.
As it stands right now the move to TGLCanvas appear to contain some known-unknowns and maybe some unknown-unknowns that we are not ready to take on. Even tough TGLCanvas solves this particular issue, we have decided to stay with the GDI+ and just avoid the problematic styles when we need real-time performance.
Best regards,
Ags
Post by Yeray » Thu Jan 23, 2025 2:02 pm
Hello Ags,
Thanks for the explanation.
I hope we can invest more time on improving the TGLCanvas so it can be used as a 1:1 replacement to GDI/GDIPlus.
Could you please expand a little bit on the major issues? I'm not sure to understand what are you doing in the panning event.
ags
Post by ags » Thu Feb 27, 2025 12:56 pm
Hello Yeray
We are compiling a list of changes that we observe when using TGLCanvas instead of the GDI+ canvas, but to keep the thread on track we want to respond to the question of the panning event.
What we observe is that the TChartImageTool works in a different way when panning and TChart uses the TGLCanvas. The result is that the image is not updated properly in our app when using TGLCanvas.
Our use-case is not like the example we have prepared, but the code below illustrates the issue we are trying to understand. We always run 64-bit, the app requires a MainForm with a Chart1 and hooking the FormCreate event handler.
To test, run the app and pan in the chart, using the default, mouse right button.
What you should see is that:
when using the default GDI+ canvas: The image is displaced on mouse move and updated on mouse up.
when using the TGLCanvas: The image is not updated, but seems to be switching between two images and two levels of zooming. The displayed content of TChartImageTool appear to change/alternate between two images on both left and right mouse button clicks.
Br ags
unit MainForm_;
interface
uses
  Winapi.Windows, Winapi.Messages, System.SysUtils, System.Variants, System.Classes, Vcl.Graphics,
  Vcl.Controls, Vcl.Forms, Vcl.Dialogs, Vcl.ExtCtrls, VclTee.TeeGDIPlus, VCLTee.TeEngine,
  VCLTee.Series, VCLTee.TeeProcs, VCLTee.Chart, VCLTee.TeeTools, Math,
  VCLTee.TeeGLCanvas {Requires package TeeGL929}
type
  TForm1 = class(TForm)
    Chart1: TChart;
    procedure Chart1MouseDown(Sender: TObject; Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
    procedure Chart1MouseMove(Sender: TObject; Shift: TShiftState; X, Y: Integer);
    procedure Chart1MouseUp(Sender: TObject; Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
    procedure Chart1Scroll(Sender: TObject);
  private
    { Private declarations }
    FDragging: Boolean;
    FStartX, FStartY: Integer;
    ImageTool: TChartImageTool;
    PointSeries: TPointSeries;
    BufferImage: TPicture;
    XDisplacement: Integer;
    YDisplacement: Integer;
    procedure UpdateCenterCoordinates;
  public
    { Public declarations }
  Form1: TForm1;
implementation
{$R *.dfm}
procedure TForm1.FormCreate;
//  Chart1.Canvas := TGLCanvas.Create; // use or dont OpenGL canvas to see difference in behaviour when panning
  Chart1.OnMouseUp := Chart1MouseUp;
  Chart1.OnScroll := Chart1Scroll;
  Chart1.BottomAxis.SetMinMax(-5, 5);
  Chart1.LeftAxis.SetMinMax(-5, 5);
  PointSeries := TPointSeries.Create(Self);
  PointSeries.Clear;
  PointSeries.AddXY(-5, -5);
  PointSeries.AddXY( 5,  5);
  PointSeries.Visible := True;
  Chart1.AddSeries(PointSeries);
  BufferImage := TPicture.Create();
  BufferImage.Bitmap.SetSize(100, 100); // Set the size of the image
  ImageTool := TChartImageTool.Create(Self);
  ImageTool.ParentChart := Chart1;
  ImageTool.Series := PointSeries;
  ImageTool.Picture.Assign(BufferImage);
  ImageTool.Visible := True;
  Chart1.Tools.Add(ImageTool);
  FDragging := True;
  FStartX := X;
  FStartY := Y;
  if FDragging then
    XDisplacement := (X - FStartX);
    YDisplacement := (Y - FStartY);
procedure TForm1.Chart1MouseUp(Sender: TObject; Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
  FDragging := False;
procedure TForm1.Chart1Scroll(Sender: TObject);
    // Draw picture - displaced
    ImageTool.Picture.Bitmap.Canvas.Brush.Color := clSkyBlue;
    ImageTool.Picture.Bitmap.Canvas.FillRect(Rect(0, 0, ImageTool.Picture.Bitmap.Width, ImageTool.Picture.Bitmap.Height));
    ImageTool.Picture.Bitmap.Canvas.Draw(XDisplacement, YDisplacement, BufferImage.Graphic);
    PointSeries.Repaint;
    ImageTool.Repaint;
procedure TForm1.UpdateCenterCoordinates;
  CenterX, CenterY: Double;
  ChartCenterX, ChartCenterY: Integer;
  BufferImage.bitmap.SetSize(Max(100, Chart1.ChartRect.Width), Max(100, Chart1.ChartRect.Height));
  ChartCenterX := BufferImage.bitmap.Width div 2;
  ChartCenterY := BufferImage.bitmap.Height div 2;
  CenterX := Chart1.BottomAxis.CalcPosPoint(ChartCenterX);
  CenterY := Chart1.LeftAxis.CalcPosPoint(ChartCenterY);
  BufferImage.bitmap.Canvas.FillRect(Rect(0, 0, BufferImage.bitmap.Width, BufferImage.bitmap.Height));
  BufferImage.bitmap.Canvas.TextOut(ChartCenterX-40, ChartCenterY-5, Format('Center: (%.1f, %.1f)', [CenterX, CenterY]));
end.
ags
Post by ags » Fri Mar 07, 2025 10:54 am
Hello Yeray
Now that we, with your kind assistance, have realized that some of our challenges with TChart redraw performance is related to GDI+ we are looking at ways to work around this. However due to the differences in graphics and behavior we have seen when replacing the GDI+ canvas with the TGLCanvas, the TGLCanvas is not our main focus.
Before we move on from the tests of the TGLCanvas here is a list of the issues that we noted. We are not expecting or waiting for an answer, this is just feedback.
- GLCanvas draws TChartImageTool.Picture.Bitmap mirrored both horizontally and vertically, if used with Bitmap.TransparentColor := clWhite; Bitmap.Transparent := True;
However GLCanvas does give a huge performance boost compared to GDI+ when displaying a partly Transparent image.
- GLCanvas draws fuzzy lines when showing eg. a curve like a Bezier spline, but also when showing straight lines, penstyles appear to be drawn using an altogether different method when using TGLCanvas
- GLCanvas draws lines for TLineSeries that were previously not drawn.
It appears that GLCanvas does not react to LineSeries.LinePen.Visible. This can be “fixed” by using LineSeries.Transparency instead.
- GLCanvas draws left axis title a lot closer to the axis labels than GDI+. So close it looks unfortunate eg. when left axis labels are long.
- GLCanvas draws TAnnotationTool text outside to the bottom edge when using PositionUnits := muPixels and Shape.CustomPosition and AnnotationTool.Top := Chart.Top + Chart.Height - (AnnotationTool.Height);
Annotations does not go outside the visible area with the same settings in GDI+.
br Ags
