Integration with QuickReport v7?
Toreba
Post by Toreba » Thu Jun 19, 2025 9:01 am
I'm told by the QuickReport retailer Barnsten that integration with QRv7 is something Steema are working on. Do you know when it might be ready?
In the meantime, where do I download the latest for Delphi 12?
Toreba
Re: Integration with QuickReport v7?
Post by Yeray » Fri Jun 20, 2025 6:03 am
Hello Toreba,
Give it a try at this:
Tee9QR7D29.zip
Toreba
Post by Toreba » Thu Jun 26, 2025 10:09 am
Hello Yeray,
Thanks for the link to the download.
I do have problems, however.
On a new machine, I installed Delphi 12 without standard TeeChart and without standard QuickReport. I installed the professional versions of both.
I followed the instructions, I think, at https://www.steema.com/docs/pdf/QuickReport.pdf. The two QRTee packages build fine, the design time package installs fine.
But when I attempt to run a test project, I get the message 'Unit QrTee was compiled with a different version of VCLTee.Chart.TCustomChart'.
I'm struggling to understand how that is possible, or where to look for the wrong dependencies.
Can you help?
Toreba
Post by Yeray » Thu Jun 26, 2025 10:51 am
Hello Toreba,
Check if you have a QrTee unit in any of the folders in your "Library path" and make sure the first to be found is the one you just compiled.
