Timescale in ganttchart
Hans
Post by Hans » Mon Jan 24, 2005 9:08 am
If I set the x-scale to f.e. week for a gantt planning tool, the I get a timescale from monday 0:00 up to sunday 23:59.
Is it possible to show only dayparts like form 08:00 up to 17:00 as working time and then skip the 17:00 to 08:00 and go directly to the next day 08:00?
I like to show only the dayparts from f.e. 08:00 to 17:00.
Is that possible?
Post by Pep » Tue Jan 25, 2005 9:21 am
Hi Hans,
yes, that's possible. This has to be done manually. There is an example of this feature available in TeeChart Pro demo features project (All Features -> Welcome ! -> Chart Styles -> Candle -> Axis Labels no Weekends ).
Hans
Post by Hans » Fri Feb 11, 2005 1:32 pm
Pep,
I downloaded your demo, but can't find the sourcecode, allthough I configured to the sources directory.
What to do?
Hans
Post by Narcís » Fri Feb 11, 2005 2:53 pm
Hi Hans,
You should set the sources path to "C:\Program Files\Steema Software\TeeChart 7 for Delphi X\Examples\Features" (Deaful English installation path). Another solution would be openning the full features demo project with Delphi so there you have the source code.
Hans
Post by Hans » Fri Feb 11, 2005 3:49 pm
I'm sorry, but that directory doesn't exist.
The instal directory is : C:\Program Files\Steema Software\TeeChart Pro v7.02 Full Source Code\Sources
And the demo file is the executable file I downloaded from the site.
Hans
Post by Narcís » Fri Feb 11, 2005 3:58 pm
Hello Hans,
Ok, that's because you are source code customer.
For the demo source code you should download and install the binary installer from the Customer Download Area. This will install TeeChart components, help files, demos, examples, tutorials, etc.
Hans
OK, and now the problem
Post by Hans » Fri Feb 11, 2005 4:09 pm
I can't find All Features -> Welcome ! -> Chart Styles -> Candle -> Axis Labels no Weekends .
I have Chart styles->other->big candle, but no other candle with period blocking.
Hans
Hans
Found the candle
Post by Hans » Fri Feb 11, 2005 4:19 pm
Found the candle without weekends.
But I cannot see how to program the skip of timeperiods on the X-scale.
Could you send me that code?
Hans
Hans
Code requested
Post by Hans » Mon Feb 14, 2005 4:09 pm
I would like to have some code to create the x-scale without the "night" hours.
Could you please help me, because in the examples I cannot find anything
Hans
Marjan
Post by Marjan » Tue Feb 15, 2005 10:45 am
Hi, Hans.
I did an example of "removing weekends" a while ago for another customer. Please check the following post.
The example removes whole days, but using the same approach you can also remove hours.
Marjan Slatinek,
Hans
Post by Hans » Tue Feb 15, 2005 4:47 pm
Marjan, thanks
I have a possibility to change between day, week and month, so the x-scale should be recalculated everytime after switching.
I tried to do following to see what happened: "Planbord.Axes.Bottom.Items.Clear;"
But where I tried it, everytime the X-axis were there again.
On_beforedrawaxis
On_beforedrawseries
Where can change this? At that place I can try your suggestion of creating new bottom axis.
Hans
Marjan
Post by Marjan » Wed Feb 16, 2005 7:14 am
Hi, Hans.
I'd place the Clear (and repopulation) part in the same procedure you use to switch between different datetime formats. But you must repopulate axis labels (Items) - otherwise TeeChart internal algorithm will take over and generate the "usual" set of labels (no gaps).
Marjan Slatinek,
Hans
Post by Hans » Thu Feb 17, 2005 3:51 pm
Marjan,
I tried something, but only see the labels change and not the gridlines.
I want to skip completely all gridlines and labels during the night.
So the last line to today is 17:00 and the next one(direct to the last ond of 17:00) is the 09:00 of tomorrow.
With each gridline at the same distance I like to see:
09:00 11:00 13:00 15:00 17:00 09:00 11:00 13:00 15:00 17:00 09:00 etc.
1. Is this possible?
2. How to do that? with code examples please.
Hans
Hans
help code wanted
Post by Hans » Mon Feb 21, 2005 2:30 pm
Marjan,
Could you please help me?
Hans
Marjan
Post by Marjan » Thu Feb 24, 2005 10:31 am
Hi, Hans.
Using the *same* approach I quoted couple of posts above this one I was able to plot two days according to your specifications. With slight modifications you can use it for whole week, month, ...
  private
    { Private declarations }
    ValidDates: Array [0..100] of TDate;
    DateCount : Integer;
  public
    { Public declarations }
  Form1: TForm1;
implementation
{$R *.dfm}
var i: Integer;
  // generate dates ... you can get this from sql, etc...
  DateCount := 10;
  // day 1
  ValidDates[0] := EncodeDate(2005,1,31)+EncodeTime(9,0,0,0);
  ValidDates[1] := EncodeDate(2005,1,31)+EncodeTime(11,0,0,0);
  ValidDates[2] := EncodeDate(2005,1,31)+EncodeTime(13,0,0,0);
  ValidDates[3] := EncodeDate(2005,1,31)+EncodeTime(15,0,0,0);
  ValidDates[4] := EncodeDate(2005,1,31)+EncodeTime(17,0,0,0);
  // day 2
  ValidDates[5] := EncodeDate(2005,2,1)+EncodeTime(9,0,0,0);
  ValidDates[6] := EncodeDate(2005,2,1)+EncodeTime(11,0,0,0);
  ValidDates[7] := EncodeDate(2005,2,1)+EncodeTime(13,0,0,0);
  ValidDates[8] := EncodeDate(2005,2,1)+EncodeTime(15,0,0,0);
  ValidDates[9] := EncodeDate(2005,2,1)+EncodeTime(17,0,0,0);
  // populate bottom axis with labels
  // in this example user every 3rd label
  Chart1.Axes.Bottom.Items.Clear;
  for i := 0 to DateCount-1 do
    if i mod 2 = 0 then // show every 2nd label - otherwise you might end up with overlapped labels
      Chart1.Axes.Bottom.Items.Add(i,DateToStr(ValidDates[i])+#13+TimeToStr(ValidDates[i]));
  Chart1.Axes.Bottom.SetMinMax(0,DateCount-1);
  Chart1.Axes.Bottom.LabelsAngle := 90;
function FindMatch(value: TDate; pool: Array of TDate; Const lo_bound, hi_bound: Integer): Integer;
var i: Integer;
  Result := -1;
  for i := lo_bound to hi_bound do
    if value=pool[i] then
      Result := i;
      break;
var xvals: Array[0..6] of TDateTime;
    yvals: Array[0..6] of double;
    i, xind: Integer;
  // this is only sample array (example)
  // 1st day data
  xvals[0] := EncodeDate(2005,1,31)+EncodeTime(9,0,0,0);
  yvals[0] := 5.2;
  xvals[1] := EncodeDate(2005,1,31)+EncodeTime(11,0,0,0);
  yvals[1] := 7.2;
  xvals[2] := EncodeDate(2005,1,31)+EncodeTime(13,0,0,0);
  yvals[2] := 1.2;
  xvals[3] := EncodeDate(2005,1,31)+EncodeTime(15,0,0,0);
  yvals[3] := 5.8;
  xvals[4] := EncodeDate(2005,1,31)+EncodeTime(17,0,0,0);
  yvals[4] := 5.8;
  // 2nd day data
  xvals[5] := EncodeDate(2005,2,1)+EncodeTime(9,0,0,0);
  yvals[5] := 5.2;
  xvals[6] := EncodeDate(2005,2,1)+EncodeTime(13,0,0,0);
  yvals[6] := 7.2;
  // Add points to series
  // Note that points have real date x values =>
  // you have to map each value to internal index array
  Series1.Clear;
  for i := 0 to High(xvals) do
    xind := FindMatch(xvals[i],ValidDates,0,DateCount-1);
    if xind <> -1 then Series1.AddXY(xind,yvals[i]);
Marjan Slatinek,
