Exceptions with Version 2025.44
gkobler
Post by gkobler » Tue Jul 29, 2025 5:48 am
Hello
I installed the new version 2025.44 and noticed some problems with my program.
After investigation, i create a small demo program, see attachment.
Compile it with v44, the start it and press the "view" button, then "hide". then you got a exceptions. I also got an exception, when i delete a Series at design time in the IDE.
Compile and run it with <=V43 it runs without any problems.
Delphi 12.3.1 Build the program with Win32 and Win64.
Hope this will be fixed.
Thanks in advanced
Gregor
TestTChart.7z
(70.95 KiB) Downloaded 7 times
Re: Exceptions with Version 2025.44
Post by Yeray » Tue Jul 29, 2025 7:22 am
Yes, that's a side effect of a bug in v2025.44 (#2777), which was identified and fixed here.
Find below the full git diff:
--- a/Chart.pas
+++ b/Chart.pas
@@ -418,6 +418,7 @@ type
     ILegend : TCustomChartLegend;
+    procedure FontChanged(Sender: TObject);
     function GetFont:TTeeFont;
     procedure SetAlign(const Value:TCanvasTextAlign);
     procedure SetCustom(SetPos:Boolean);
@@ -5519,6 +5520,14 @@ begin
   result:=Assigned(FFont);
+procedure TLegendItem.FontChanged(Sender: TObject);
+begin
+  SetCustom(False);
+  if Assigned(ILegend) then
+    ILegend.CanvasChanged(Sender);
+end;
 function TLegendItem.GetFont:TTeeFont;
 var Old : Boolean;
@@ -5536,6 +5545,12 @@ begin
         FFont:=TTeeFont.Create(nil);
+  {$IFDEF FMX}
+  FFont.Brush.OnChanged:=FontChanged;
+  {$ELSE}
+  FFont.OnChange:=FontChanged;
+  {$ENDIF}
   result:=FFont;
@@ -5635,11 +5650,6 @@ begin
     result:=TLegendItem.Create;
     result.ILegend:=ILegend;
-    if ILegend.InternalLegendStyle=lsAuto then
-       ILegend.CalcLegendStyle;
-    result.Text:=ILegend.FormattedLegend(Index);
     inherited Items[Index]:=result;
gkobler
Post by gkobler » Tue Jul 29, 2025 7:59 am
Ok, thanks. Will Steema create a new installer to fix that?
Post by Yeray » Tue Jul 29, 2025 8:20 am
Yes, we'll publish new installers as soon as possible.
gkobler
Post by gkobler » Tue Jul 29, 2025 9:07 am
Thanks a lot :-)
