Changing serie colour
Vectar
Post by Vectar » Thu Mar 10, 2005 9:57 pm
Hi folks,
I have a bar chart in which the user can change bar colours programmatically. The colour of the bar changes OK but the corresponding colour in the chart legend remains as it was before the change. In V5 the legend colour changed with the bar colour (I think) but not in V7.
How do I persuade the legend colour to change?
John
Marjan
Post by Marjan » Fri Mar 11, 2005 8:24 am
Hi.
Perhaps the problem is the ColorEachPoint property is set to True and you're only changing individual series points ? In this case internal legend drawing routine uses series Color and not the specific point color.
If this is the case the setting barSeries.SeriesColor (or barSeries.Color) property to specific color will do the trick.
Marjan Slatinek,
Vectar
Post by Vectar » Fri Mar 11, 2005 7:44 pm
Hi Marjan,
The code I'm using is below.
procedure TDataForm.On1Click(Sender: TObject);
  with ColorDialog1 do
    Options := [];
    if Execute then OnColour := Color;
    with Chart1.Series[ 0 ] do
      SeriesColor := Color ;
    Grafit(Treatnumb,Numb);
As you can see, I'm using SeriesColor but the legend colour doesn't change. Do you have any other idea what might be wrong, please?
Post by Narcís » Mon Mar 14, 2005 10:43 am
Hi Vectar,
It works fine here using SeriesColor and assigning a ColorDialog.Color to it. You may use Chart1.Legend.Repaint or Chart1.Legend.Draw to force the legend being redrawn.
If this doesn't work could you please send us a small example project we can run "as-is" to reproduce the problem here? You can post it at [url]news://www.steema.net/steema.public.attachments[/url] newsgroup.
Vectar
Post by Vectar » Tue Mar 15, 2005 8:18 pm
Hi Narcis,
I've tried your suggestions but neither option forces the change of colour in the legend. So I've posted the project as you suggested.
John
Post by Narcís » Wed Mar 16, 2005 11:12 am
Hi John,
I can't see your example in the newsgroups. Would you be so kind to check it an post it again if necessary?
Vectar
Post by Vectar » Thu Mar 17, 2005 7:38 pm
Hi Narcis,
I've posted the project again and this time it's there!
John
Post by Pep » Fri Mar 18, 2005 12:29 pm
Hi John,
using the following code works fine (just add ColorDialog1 before Color) :
    Options := [];
      SeriesColor := ColorDialog1.Color ;
    Chart1.Legend.Draw;
Vectar
Post by Vectar » Sun Mar 20, 2005 11:08 pm
Thanks Josep. That's sorted the problem.
John
