TPolar is only 1 color and printing wrong
York
Post by York » Tue Apr 26, 2005 7:23 am
I'm using TeeChart 5.02 with Delphi 6 and want to use a TPolar series. I've encountered the folowing problems :
1) I'm unable to change line color from one point to another.
2) When printing the plots arn't circular even with proportional on.
Is there any tricks that I can use, or are the issues solved in a later release ?
Post by Narcís » Tue Apr 26, 2005 8:32 am
Hi York,
You can do it changing series pen color:
Series1.Pen.Color:=clBlue;
You should set circled property to true:
Series1.Circled:=true;
Also notice that both properties can be configured using the chart editor at design-time.
What I suggested can be done using v5.02, however current version (v7.04) has many more features, enhancements, ... If you are interested you can download the fully functional evaluation version which includes a features demo that has examples of almost all features.
York
Post by York » Tue Apr 26, 2005 9:44 am
Hi Narcis,
Thank You for the answer, but...
If I use Series1.Pen.Color:=clBlue the entire line will change color. I just want a segment between two points to change color like a TLineSeries can do it.
I'm using the property Series1.Circled:=true and the series is a circle on screen, but not when printed. Even with proportional on.
Can version v7.04 function with Delphi 6 or do I have to upgrade ?
Post by Pep » Tue Apr 26, 2005 2:07 pm
This cannot be done with the existing version, you only can change the entire line or the a specific pointer using Series1.ValueColor[x] property.
This is a known bug, already added on our bug list. The whole problem is on screen ratio is not fully respected (because some circles are adjusted to fit in specific rectangle). We are aware of this problem and will try to find a better solution for nexr releases.
In the meantime, try using the StretchDraw print trick :
var tmpMeta: TMetafile;
  Chart1.BevelOuter := bvNone;
  Chart1.Frame.Visible := False;
  tmpMeta := Chart1.TeeCreateMetafile(True,Chart1.ClientRect);
  try
    Printer.Orientation := poLandscape;
    Printer.BeginDoc;
    try
      Printer.Canvas.StretchDraw(Rect(10,10,Printer.PageWidth - 10,
Printer.PageHeight - 10),tmpMeta);
    finally
      Printer.EndDoc;
  finally
    tmpMeta.Free;
The key point is your printer drawing rectangle has the same proportions as original chart. If this is obeyed, then the circles will be round when printed too.
Yes, the TeeChart v7.04 can work work Delphi6 (with all the updates).
York
Post by York » Wed Apr 27, 2005 1:04 pm
Hi Pep,
Thank You very much. I'll look forward to the bug fix and try to convince our financial department to buy an opgrade :)
