Rodrigue
- Newbie
Post
by Rodrigue » Tue May 03, 2005 3:54 pm
How to fill with color the zone between the graph and horizontal "0" ?
I've done a picture to be more precis (green serie):
http://www.xoogle.org/GRAPH-DIFF.gif
Note : I use Custom Axes...
Cordially,
Rodrigue
Post
by Pep » Fri May 06, 2005 8:38 am
Hi Rodrigue,
you could use one ColorBand Tool for the left Axis (see Help for details).
Rodrigue
- Newbie
Post
by Rodrigue » Thu May 12, 2005 11:32 am
I don't understand why you ask me to use a ColorBand tool... It's just a rectangle, no
I've used a TAreaSerie to solve my problem but I've a lot of point to display (~30000). Is it a way to only draw the point necessary (like the DrawAllPoints property available in TFastLineSerie).
Thanks in advance!
Cordially,
Rodrigue
Marjan
Post
by Marjan » Thu May 12, 2005 2:16 pm
Hi.
Yes, you can use area or even high-low series to fill the area. But you'll have to manually calculate reduction points and pass them to series. Perhaps you can even use the reduction algorithm we used in TDownSamplingFunction (see TeeChart demo to see it in action).
Rodrigue
- Newbie
Post
by Rodrigue » Wed May 18, 2005 10:05 am
I'm using C++ Builder 6.
I try to to do this :
TDownSamplingFunction* DS = new TDownSamplingFunction(Chart);
but TDownSamplingFunction is an unknow type.
Have an idea ? What file should I include ?
I don't find the example you've said. The find function in your example application doesn't work for me...
Cordially,
Rodrigue
Post
by Narcís » Wed May 18, 2005 10:26 am
Hi Rodrigue,
You should include TeeDownSampling.hpp.
Yes, you are right. It is a known problem and we will try to solve it for future releases.
Regarding the example I've seen it is not implemented in the BCB demo, however it's in the Delphi one which you can download
here. You should browse
All Features\Welcome!\ Functions\Extended\Reducing number of points.
Rodrigue
- Newbie
Post
by Rodrigue » Wed May 18, 2005 1:38 pm
Thank you very much, it works!
Rodrigue
- Newbie
Post
by Rodrigue » Wed May 18, 2005 3:05 pm
I've yet an another problem :
I don't find how to delete the object TDownSamplingFunction without generate an exeption !
Here is my code :
serie = new TAreaSeries((TChart *)Chart);
DownSampling = new TDownSamplingFunction((TChart *)Chart);
serie_temp = new TAreaSeries((TChart *)Chart);
=== Données ===
serie_temp->FillSampleValues(30000);
serie->SetFunction(DownSampling);
DownSampling->Tolerance = 10;
DownSampling->DownSampleMethod = dsAverage; /*dsDouglas - the Douglas-Peucker simplification algorithm
dsMax - group of points are replaced with group maximum value
dsMax - group of points are replaced with group minimum value
dsMinMax - group of points are replaced with (two points!) group minimum AND
maximum value
dsAverage - group of points are replaced with group average value*/
Chart->AddSeries(serie);
serie->DataSource = serie_temp;
serie->VertAxis = aLeftAxis;
serie->HorizAxis = aBottomAxis;
And when I repaint an another serie or when the window is closed, the following code are executed :
if(DownSampling) delete DownSampling;
An exception is generated
! May be I'm doing something wrong ...
TIA
Cordially,
Rodrigue
Marjan
Post
by Marjan » Wed May 18, 2005 3:42 pm
Hi.
I think you have to disconnect function from serie prior to deleting it (to avoid av later when serie values are recreated):
serie->SetFunction(NULL);
Rodrigue
- Newbie
Post
by Rodrigue » Wed May 18, 2005 4:20 pm
I've try but it doesn't work !
CodeGuard error : Access in freed memory
Rodrigue
- Newbie
Post
by Rodrigue » Thu May 19, 2005 9:53 am
Ok, I must delete TDownSamplingFunction object in first. And only after do setfunction(NULL).
When I zoom, I need a better resolution. I was thinking that put Tolerance to 1 will only display the "average pixel" (with DownSamplingMethod = dsAverage) on the screen independently of the factor of zoom
I've tried to put Tolerance=1 in the OnZoom Event but it doesn't work also
TIA,
Cordially,
Rodrigue
Post
by Pep » Wed Jun 15, 2005 3:40 pm
Hi Rodrigue,
I've tried to change the Tolerance in the OnZoom event here and it works fine. Could you please send me a simple sample directly to my mail (
pep@steema.com) with which I can reproduce the problem ? Have you tried to call the CheckDataSource() method after the Tolerance has been modified ?
