Changing Circled labels in Polar Series
Johan Ingemansson
Post by Johan Ingemansson » Thu May 26, 2005 9:50 am
I want to do a so called spider diagram using the TPolarSeries, in a spider diagram the labels of the replies should be displayed where the circled labels are now. Is there anyway of changing theese labels?
I´ve read another post where Steema recommended overriding the default settings in the creation of theese labels, the problem is that theese labels aren´t the same everytime.
Johan Ingemansson
Post by Pep » Thu May 26, 2005 11:38 am
Hi Johan,
the only way around this is to manually draw axis labels on chart Canvas. You could use the TCanvas.RotateLabel method to draw axis label at specific position (in the OnAfterDraw event). The trick is (obviously) to calculate correct position and (more importantly) check for overlaps. The first part is already done in TeePolar.pas (which you can update if you're source code customer) , the second part still has to be improved.
Johan Ingemansson
Calculating axis etc.
Post by Johan Ingemansson » Thu May 26, 2005 12:27 pm
Hi Pep,
Ok, I´ll do that, already have an "anti" overlapping algorithm, which I should be able to apply here! Thx!
Johan Ingemansson
:D
Johan Ingemansson
Maybe a stupid "sub" question
Post by Johan Ingemansson » Thu May 26, 2005 1:34 pm
Hi again,
One moore thing, I have set the PositionUnits:=muPixels on all axes. If I take for example:
Chart1.Axes.Bottom.IEndPos-Chart1.Axes.Bottom.IStartPos
and now I do the same for the left axis, then theese values are not the same, in my case there is a 3 pixel difference, shouldn´t theese axes be exactly the same if a symmetric circle should be created? I have also set ASerie.Circled:=True.
Johan Ingemansson
Post by Narcís » Thu May 26, 2005 2:18 pm
Hi Johan,
It works fine for me here using latest TeeChart version (v7.04). Which version are you using?
Also notice that Chart1.Axes.Bottom.IAxisSize is the same as doing Chart1.Axes.Bottom.IEndPos-Chart1.Axes.Bottom.IStartPos:
  Series1.FillSampleValues();
  Series1.Circled:=true;
  Memo1.Clear;
var i: Integer;
  for i:=0 to Chart1.Axes.Count - 1 do
    With Chart1.Axes[i] do
      PositionUnits:=muPixels;
      Memo1.Lines.Add(IntToStr(i) + ': ' + IntToStr(IAxisSize));
Johan Ingemansson
Axis size
Post by Johan Ingemansson » Thu May 26, 2005 2:31 pm
Thanks for the advice of IAxisSize! I´m currently using TeeChartPro 7.01 with source code, I still get this problem that is, the right/left axis is three pixels longer then bottom/top axis, but then it must be a version difference. Thank you for your quick response!
Johan Ingemansson
