Drawing a dotted line
Post by Newbie » Wed Jun 08, 2005 8:34 pm
I have created a chart, TeeChart 7.02, drawing 2 TLineSeries, each line is about 2000 points. One of them needs to be dotted or dashed style. When setting TLinePen to dotted (small dots True), you don't see a dotted line because the dots are drawn between points. And with 2000 points in a trace, you don't see them. That is obvious. However, I need to have this one line dotted, without reducing points. I have done it now by using AddNullXY every .. points, but I assume there must be an easy way to get a dotted line right away, no matter how many points are in the trace?
Thanks in advance,
Davy
Post by Narcís » Thu Jun 09, 2005 11:44 am
Hi Davy,
Using v7.04 (latest version available at our customer download area) and the code below you can cleary see Series2 being small-dotted.
  Series1.FillSampleValues(2000);
  Series2.FillSampleValues(2000);
  Series2.Pen.SmallDots:=true;
If you don't succedd on this could you please send us an example we can run "as-is" to reproduce the problem here?
You can post your examples at [url]news://www.steema.net/steema.public.attachments[/url] newsgroup.
Post by Newbie » Thu Jun 09, 2005 6:44 pm
Hi Narcis,
Have tried your code with 7.04 and that works well indeed.
My code is a bit different as you might assume
Note when zooming in you see a dotted line between points.
procedure TForm1.Button2Click(Sender: TObject);
// This code does not draw a dotted line
  i: integer;
  j: double;
  for i := 0 to Chart1.SeriesCount - 1 do
    Chart1.Series[i].Clear;
  j := 0;
  for i := 0 to 1999 do
    Series1.AddXY(i,j);
    Series2.AddXY(i,j + 50);
    j := j + 0.2;
    // j := j + 1; // Makes no difference
  Series2.Pen.SmallDots := True;
Any clue?
Thanks a lot for your efforts,
Davy
Post by Narcís » Fri Jun 10, 2005 8:14 am
Hi Davy,
I can reproduce the problem with your code. It happens because your points are very close one to another. You could try using another pen style as dots, for example, and increase its size. However it won't work because it will end making a thick line.
Depending on how are your points distributed you can play a little with pen styles and sizes to see if there's a combination that fits your needs.
Post by Newbie » Fri Jun 10, 2005 5:48 pm
Hi Narcis,
Playing around with pen styles and so on does not makes any sense in this application. Infact, the graph is used as a sweepchart with a pre-defined no of points, where every 200 ms a point is overwritten with a new one, so the graph cycles around every 2000 / 5 = 400 seconds. It is an data acquisition application. If I reduce points, customer information gets lost.
I think it is a bit of un-intended behavior of the chart, because FillSampleValues does what it should do. Could Steema address this please?
Kind regards,
Davy
Post by Newbie » Tue Jun 14, 2005 10:21 pm
Hi Narcis,
I have not seen any reply to my last message yet, therefore again:
Kind regards,
Davy
Post by Pep » Wed Jun 15, 2005 9:24 am
Hi Davy,
FillSampleValues works in the same manner, but it normally does not reproduce a straight line. If you modify the following lines in your code you will see the same as using FillSampleValues :
    Series1.AddXY(i,j);
    Series2.AddXY(i,Random(350) + 50);
    j := j + 0.2;
A solution for this problem could be using TFastLineSeries instead of TLineSeries.
