Functions, period range and data leak
stsl
Post by stsl » Wed Nov 02, 2005 6:35 pm
I have values every days (x = datetime) with a leak of ten days in my data.
When i add a function (average for example) with a period of 1 day, i have a calculated curve with y = 0 during the period range of the data leak (even IncludeNulls = false).
How is it possible to avoid these null values ?
I woul'd like to have a discontinuous curve when there is no data.
[/img]
Post by Pep » Mon Nov 07, 2005 8:14 am
have you AddNull method for the leak data ?
You can see one example which shows how to do this in the Demo features project (included into the TeeChart Pro installation) under :
All Features -> Welcome ! -> Functions -> Standard -> Average -> Average and Nulls
stsl
Null data
Post by stsl » Mon Nov 07, 2005 9:55 am
It's not null data : i haven't data during this short period.
We are working on real time charting (sensors monitoring). if you shutdown, your system, there is no data...
stsl
Data leak during a period and function like median
Post by stsl » Mon Feb 25, 2008 8:14 am
This is and old and annoying bug.
It's not normal to have a calculated curve with values equal to 0 during a data leak. Please, how is it possible to bypass this bug.
Don't add calculated values if you don't have data durin a period.
stsl
Function and null values or no data (teEngine.pas)
Post by stsl » Mon Feb 25, 2008 3:02 pm
The problem is that in the Calculate function, the result is 0, even all the data of the period are null values.
If there is no data in a period, i don't know why there is a calculation on this period an why the result is an arbitrary value (0 is a significant value).
Is it possible to have something like that (teEngine.pas) and how to do that:
Procedure TTeeFunction.CalculatePeriod( Source:TChartSeries;
                                        Const tmpX:Double;
                                        FirstIndex,LastIndex:Integer);
  if Source.DataInPeriod(FirstIndex, LastIndex) then
   AddFunctionXY( Source.YMandatory,       tmpX,Calculate(Source,FirstIndex,LastIndex) );
stsl
function and data leak
Post by stsl » Mon Apr 07, 2008 6:22 am
Is-it possible to have a response ? I think that it's a bug because 0 is a value and different than "no value"....
Post by Yeray » Mon Apr 07, 2008 10:13 am
Hi stsl,
I've added the feature request to the wish list (TV52012945) to be reviewed and, if possible, enhanced in further releases. This may be quite a sensible issue as implementing it as you request may break existing clients code.
Also notice that we don't provide support for changes to the source code but you are free to implement the necessary customizations to fit your needs.
stsl
function and all values
Post by stsl » Tue Nov 04, 2008 10:35 am
There is always the same problem in the last version (8.04). There is a property IgnoreNulls in the Exponential moving average function. Why not in the other function ? It's incredible. All the calculations are wrong, if you assimilate Null values as 0 values...
Please, do something, i wrote my first post in 2005....
Post by Narcís » Tue Nov 04, 2008 10:46 am
Hi stsl,
Thanks for your feedback. I've increased item's priority on the list.
Post by Yeray » Tue Apr 07, 2009 11:47 am
Hi stsl,
Testing a little bit further in this, I've tried adding 2 null values to define the interval where you don't get data (having period=2), and with a little trick it seems to work fine. Could you please test this and see if it works as you wish?
var i, j: Integer;
  Series2.FunctionType.Period := 2;
  for i:=0 to 30 do
    if ((i<10) or (i>20)) then
      Series1.AddXY(i,random);
    if (i=10) or (i=20) then //Start or Stop
      Series1.AddNull();
  Series2.CheckDataSource;
  for j:=0 to Series2.Count-1 do
    if Series2.YValues[j] = Series2.DefaultNullValue then
      Series2.ValueColor[j]:=clNone;
  Series2.TreatNulls:=tnDontPaint;
Note two things:
1. In this example we have Series1 as source and Series2 is the line series linked to an average function.
2. Where I call Series2.DefaultNullValue, you probably won't be able to since this is a new implementation in the sources that will be available with the next maintenance release. You can use a "0".
stsl
Post by stsl » Thu Apr 09, 2009 8:53 am
I can't test it. In my release, DefaultNullValue is not declared.
An other thing: In my case, i haven't values during a period bigger than the function period (not null values, it's "no values"). So, your test code should be :
var i, j: Integer;
  for i:=0 to 30 do
    //if (i=10) or (i=20) then //Start or Stop
    //  Series1.AddNull();
Best regards
Post by Yeray » Thu Apr 09, 2009 9:47 am
Hi stsl,
stsl wrote:In my release, DefaultNullValue is not declared.
As I said above, this property will be available in the next maintenance release. Please, use a 0 instead of this property in the meanwhile.
Resuming:
If I understand well, you have a process that adds points to your source. The problem is because you have gaps in your X values and you also have an average function and you would like this function not to be drawn in these gaps.
Here you have two options:
1. If your continuous intervals match with the function period, you could process as described before. You could add as null values to your source (series1) as your function period says every time the acquiring process stops to propagate these null values to your function (series2) to not paint them.
2. You could create a new series plus a new function every time the acquiring process starts.
stsl
Post by stsl » Thu Apr 09, 2009 12:03 pm
Excuse me, i can test with a 0 value.
Resuming:
Exactly. The problem is that the average result (not only the average) is 0 when there is gaps. It would be "null value".
NO: The intervals are defined by the user.
!!! I get the data from the database. There is no connection between the visualization process and the acquisition software.
And, if this solution would be suitable, i will have a lot of series in my legend for the same acqusition point.
Best regards
Post by Yeray » Thu Apr 09, 2009 2:45 pm
Hi stsl,
For your answers, I deduce that you are loading the data directly to your source series instead of manually retrieving data from your database and populate it using AddXY method. So I recommend you to do it and you'll be able to catch the data gaps and decide what to do:
1. You could add as many null values as your function period says. If this period is variable, you will have to re-loop your data and add or remove null values in order to have as null points as the period says. If you work in this way, maybe you'll need to reorder your series points:
Series1.XValues.Sort;
2. You could create a new series plus a new function every time the acquiring process starts. Please, take a look at the Tutorial 7, Working with functions to see some examples of how you could create functions at run time.
If you don't want so many series in your legend, you could hide them:
Series1.ShowInLegend := False;
stsl
Post by stsl » Thu Apr 09, 2009 3:23 pm
1. Get data from the database but i add them manually with addXY.
I have a lot of data and it will take a very long time to re-loop them each time the user change the intervals.
Very good !! And what about the check box ? If the user will check/uncheck one serie (2 or more series in your solution) only one part of the curve will appear/disappear. Ok, i can use a group but i need a symbol with the color of the main curve of the group but the legend doesn't support the Symbol.OnDraw when we use group !!!
So, i modified your TeeFunction unit (many thanks to teeChart bugs...) :
unit uTeeFunction;
interface
uses
  TeEngine, SysUtils, Classes, cArrays,
  Windows; //ODS
type
  TMyTeeFunction = class(TTeeFunction)
  protected
    procedure CalculateByPeriod(Source: TChartSeries; NotMandatorySource: TChartValueList); override;
  TMyCustomSortedFunction = class(TMyTeefunction)
  protected
    Tmp: TDoubleArray;
    ICount: Integer;
    FIncludeNulls: Boolean;
    procedure AddValue(const Value: Double; Index: Integer);
  protected
    function CalcResult: TChartValue; virtual; // abstract;
    procedure SetIncludeNulls(const Value: Boolean);
  public
    constructor Create(AOwner: TComponent); override;
    destructor Destroy; override;
    function Calculate(SourceSeries: TChartSeries; FirstIndex, LastIndex: Integer):
      Double; override;
    function CalculateMany(SourceSeriesList: TList; ValueIndex: Integer): Double;
      override;
    property IncludeNulls: Boolean read FIncludeNulls write SetIncludeNulls default True;
  TMyMedianTeeFunction = class(TMyCustomSortedFunction) // 6.02
  protected
    function CalcResult: TChartValue; override;
  published
    property IncludeNulls;
  TMyHighTeeFunction = class(TMyCustomSortedFunction)
  public
  published
  TMyLowTeeFunction = class(TMyCustomSortedFunction)
  public
  published
  TMyAverageTeeFunction = class(TMyTeeFunction)
  private
  protected
    class function GetEditorClass: string; override;
  public
      Double;
      override;
      override;
  published
implementation
uses
  TeeProcs;
{ TMyCustomSortedFunction }
constructor TMyCustomSortedFunction.Create(AOwner: TComponent);
  inherited;
  FIncludeNulls := True;
  Tmp := TDoubleArray.Create;
procedure TMyCustomSortedFunction.AddValue(const Value: Double; Index: Integer);
  tmpOk: Boolean;
  tt: Integer;
  ttt: Integer;
  tmpOk := False;
  for tt := 0 to Index do
    if tmp[tt] > Value then
      for ttt := Index downto tt + 1 do
        tmp[ttt] := tmp[ttt - 1];
      tmp[tt] := Value;
      tmpOk := True;
      break;
  if not tmpOk then
    tmp[Index] := Value;
function TMyCustomSortedFunction.CalcResult: TChartValue; // virtual; abstract;
  Result := 0; // A surcharger
function TMyCustomSortedFunction.Calculate(SourceSeries: TChartSeries; FirstIndex,
  LastIndex: Integer): Double;
  t: Integer;
  result := 0;
  if FirstIndex = -1 then
    FirstIndex := 0;
  if LastIndex = -1 then
    LastIndex := SourceSeries.Count - 1;
  ICount := LastIndex - FirstIndex + 1;
  if ICount > 0 then
    Tmp.Clear;
    try
      for t := FirstIndex to LastIndex do
        if SourceSeries.IsNull(t) then
          if IncludeNulls then
            Tmp.AppendItem(SourceSeries.MandatoryValueList.Value[t]);
        end
      Tmp.Sort; // dans l'ordre croissant
      Result := CalcResult;
    finally
      Tmp.Clear;
function TMyCustomSortedFunction.CalculateMany(SourceSeriesList: TList;
  t: Integer;
  ICount := SourceSeriesList.Count;
  if ICount > 0 then
    Tmp.Clear;
    try
      for t := 0 to ICount - 1 do
        if IncludeNulls or (not TChartSeries(SourceSeriesList[t]).IsNull(ValueIndex)) then
          Tmp.AppendItem(TChartSeries(SourceSeriesList[t]).MandatoryValueList.Value[ValueIndex]);
      Tmp.Sort;
    finally
      Tmp.Clear;
  end
    result := 0;
destructor TMyCustomSortedFunction.Destroy;
  Tmp.Free;
  inherited;
procedure TMyCustomSortedFunction.SetIncludeNulls(const Value: Boolean);
  if FIncludeNulls <> Value then
    FIncludeNulls := Value;
    ReCalculate;
{ TMyMedianFunction }
function TMyMedianTeeFunction.CalcResult: TChartValue;
  tmpMiddle: Integer;
  if Odd(ICount) then // impair
    TmpMiddle := (ICount - 1) div 2
    TmpMiddle := (ICount div 2) - 1;
  Result := tmp[tmpMiddle];
{ TMyTeeFunction }
procedure TMyTeeFunction.CalculateByPeriod(Source: TChartSeries;
  tmpX: Double;
  tmpCount: Integer;
  tmpFirst: Integer;
  tmpLast: Integer;
  tmpBreakPeriod: Double;
  PosFirst: Double;
  PosLast: Double;
  tmpStep: TDateTimeStep;
  tmpCalc: Boolean;
  TmpDataAvailable: Boolean;
//  TmpPeriod: Double;
  With ParentSeries do
    tmpFirst:=0;
    tmpCount:=Source.Count;
    tmpBreakPeriod:=NotMandatorySource.Value[tmpFirst];
    tmpStep:=FindDateTimeStep(Period);
    Repeat
      PosLast:=0;
      if PeriodStyle=psNumPoints then
        tmpLast:=tmpFirst+Round(Period)-1;
        With NotMandatorySource do
          PosFirst:=Value[tmpFirst];
          if tmpLast<tmpCount then PosLast:=Value[tmpLast];
      end
        tmpLast:=tmpFirst;
        PosFirst:=tmpBreakPeriod;
        TeeDateTimeIncrement(GetHorizAxis.ExactDateTime and GetHorizAxis.IsDateTime and  (tmpStep>=dtHalfMonth),
                        True,
                        tmpBreakPeriod,
                        Period,
                        tmpStep );
        PosLast:=tmpBreakPeriod-(Period*0.001);
        While tmpLast<(tmpCount-1) do
          if NotMandatorySource.Value[tmpLast+1]<tmpBreakPeriod then Inc(tmpLast)
        else break;
        // Modif SSL
        TmpDataAvailable := (NotMandatorySource.Value[tmpLast] < PosLast) and
                             (not Source.IsNull(tmpLast));
        // Modif SSL END
      tmpCalc:=False;
        { align periods }
        if PeriodAlign=paFirst then tmpX:=PosFirst else
        if PeriodAlign=paLast then tmpX:=PosLast else
                                    tmpX:=(PosFirst+PosLast)*0.5;
        if (PeriodStyle=psRange) and (NotMandatorySource.Value[tmpFirst]<tmpBreakPeriod) then
           tmpCalc:=True;
        if TmpDataAvailable then // MODIF SSL
          if (PeriodStyle=psNumPoints) or tmpCalc then
             CalculatePeriod(Source,tmpX,tmpFirst,tmpLast)
             AddFunctionXY( Source.YMandatory, tmpX, 0 );
         tmpFirst:=tmpLast+1;
    until tmpFirst>tmpCount-1;
{ TMyAverageTeeFunction }
constructor TMyAverageTeeFunction.Create(AOwner: TComponent);
  inherited;
function TMyAverageTeeFunction.Calculate(SourceSeries: TChartSeries; FirstIndex,
  t: Integer;
  tmpCount: Integer;
  if (FirstIndex = TeeAllValues) and IncludeNulls then
    with SourceSeries do
      if Count > 0 then
        result := ValueList(SourceSeries).Total / Count
        result := 0;
    end
    if FirstIndex = TeeAllValues then
      FirstIndex := 0;
    result := 0;
    tmpCount := 0;
    with ValueList(SourceSeries) do
        if IncludeNulls or (not SourceSeries.IsNull(t)) then
          result := result + Value[t];
          Inc(tmpCount);
    if tmpCount = 0 then
      result := 0
      result := result / tmpCount;
function TMyAverageTeeFunction.CalculateMany(SourceSeriesList: TList; ValueIndex:
  Integer): Double;
  t: Integer;
  Counter: Integer;
  tmpList: TChartValueList;
  result := 0;
  if SourceSeriesList.Count > 0 then
    Counter := 0;
    for t := 0 to SourceSeriesList.Count - 1 do
      tmpList := ValueList(TChartSeries(SourceSeriesList[t]));
      if (tmpList.Count > ValueIndex) and
        (IncludeNulls or (not TChartSeries(SourceSeriesList[t]).IsNull(t))) then
        Inc(Counter);
        result := result + tmpList.Value[ValueIndex];
    if Counter > 0 then
      result := result / Counter;
procedure TMyAverageTeeFunction.SetIncludeNulls(const Value: Boolean);
    ReCalculate;
class function TMyAverageTeeFunction.GetEditorClass: string;
  result := 'TAverageFuncEditor';
{ TMyHighTeeFunction }
function TMyHighTeeFunction.CalcResult: TChartValue;
  if tmp.Count > 0 then
    Result := tmp[tmp.Count - 1];
{ TMyLowTeeFunction }
function TMyLowTeeFunction.CalcResult: TChartValue;
    Result := tmp[0];
initialization
end.
