getfreeseriescolor
nicoconqueso
getfreeseriescolor
Post by nicoconqueso » Fri Feb 10, 2006 6:46 pm
Hello...
I am adding around 30-100 series to a graph at runtime, but i am running out
of new colors for the new series. How can I use the GetFreeSeriesColor
function to look for more than 16 colors? Or is there another way around
this? Thanks for your help.
Cheers,
Nico
Post by Pep » Mon Feb 20, 2006 11:08 am
Hi Nico,
a way around could be to define your custom Array of colors and use it like in the following code :
Const ColorP:Array[1..10] of TColor=
        ( clRed,
          clGreen,
          clYellow,
          clBlue,
          clWhite,
          clGray,
          clFuchsia,
          clTeal,
          clNavy,
          clMaroon
var i,c : integer;
c:= 0;
for i := 0 to 19 do
  if i mod 10= 0 then c:= 1
  else c:= c+1;
  Series1.AddXY(i,random(10),'',ColorP[c]);
or if you are a source code customer modify the Array of colors and recompile the sources.
