Color Line with Marks Tips
Krishna
Post by Krishna » Thu Aug 03, 2006 5:39 am
I have placed a color line to identify exact position of the datapoint to the X-axis.
I need to popup the Mark Tip of the datapoint if the line position matches the datapoint when I am dragging the color line along the graph drawn.
Krishna.
Post by Pep » Thu Aug 03, 2006 9:26 am
Hi Krishna,
find one example below whic does this using :
unit Unit1;
interface
uses
  Dialogs, TeEngine, Series, ExtCtrls, TeeProcs, Chart, StdCtrls, Buttons;
type
  TForm1 = class(TForm)
    Chart1: TChart;
    Series1: TLineSeries;
    BitBtn1: TBitBtn;
    procedure Chart1MouseMove(Sender: TObject; Shift: TShiftState; X,
      Y: Integer);
    procedure Chart1KeyDown(Sender: TObject; var Key: Word;
      Shift: TShiftState);
  private
    { Private declarations }
  public
    { Public declarations }
  Form1: TForm1;
  XVal : integer;
implementation
{$R *.dfm}
Series1.FillSampleValues(100);
Series1.HorizAxis :=  aBothHorizAxis;
Chart1.TabStop := true;
  Y: Integer);
var i, s, posi : integer;
begin;
  Chart1.Repaint;
  Chart1.Canvas.Brush.Style := bsClear;
  If Chart1.SeriesCount > 0 Then
   for s := 0 to Chart1.SeriesCount-1 do
    If Chart1.Series[s].Count > 0 Then begin
      For i := Chart1.Axes.Top.PosAxis To Chart1.Axes.Bottom.PosAxis do begin
        If Chart1.Series[s].Clicked(X, i) <> -1 Then posi := i;
      Chart1.Canvas.TextOut( 10, 10 + (10 * s), 'Series ' + inttostr(s) + ' Value: ' + floattostr(Chart1.Series[s].YScreenToValue(posi)));
  Chart1.Canvas.Pen.Color := clBlue;
  Chart1.Canvas.MoveTo (X, Chart1.Axes.Top.PosAxis);
  Chart1.Canvas.LineTo( X, Chart1.Axes.Bottom.PosAxis);
  XVal := X;
procedure TForm1.Chart1KeyDown(Sender: TObject; var Key: Word;
  ' you must check the key here ..( if key = ...)
  ' and depending of key increase or decrease the XVal
  XVal := Xval+1;
  Chart1.Repaint;
        If Chart1.Series[s].Clicked(Xval, i) <> -1 Then posi := i;
  Chart1.Canvas.MoveTo (XVal, Chart1.Axes.Top.PosAxis);
  Chart1.Canvas.LineTo( XVal, Chart1.Axes.Bottom.PosAxis);
end.
SteveP
Post by SteveP » Thu Aug 03, 2006 2:17 pm
Perhaps use a CursorTool with Snap = false and respond to its OnChange event. Note that with Snap=false, the OnChange event's ValueIndex will = -1. Maybe use another hidden CursorTool with Snap = true and check if the two CursorTools XValues are the same. However, the CursorTool with Snap=false has its XValue as a double and might not become set equal to the XValue of the other CursorTool that has Snap=true, even though on the chart the two CursorTools can be seen to overlap each other. The color of the CursorTools will change when they overlap.
Steve
