pssdelphi
- Newbie
Post
by pssdelphi » Tue Dec 19, 2006 8:04 pm
I have a pointer series on a chart, and I am drawing custom lines from certain points to others (not like the sequential point to point ones that are built in). The lines draw fine and scroll with the chart but they do not clip at the axis like the points in the series do. How can I get my custom lines to clip like the points in the series do?
procedure TForm1.Series1AfterDrawValues(Sender: TObject);
var x0, y0, x1, y1, x2, y2 : Integer ;
Chart1.ClipPoints:=true;
x0:=Series1.CalcXPos(0);
y0:=Series1.CalcYPos(0);
x1:=Series1.CalcXPos(1);
y1:=Series1.CalcYPos(1);
x2:=Series1.CalcXPos(2);
y2:=Series1.CalcYPos(2);
Chart1.Canvas.MoveTo( x0, y0 );
Chart1.Canvas.LineTo( x1, y1 );
Chart1.Canvas.LineTo( x2, y2 );
Thanks in advance,
David
Post
by Pep » Sat Dec 23, 2006 1:26 pm
Hi David,
you can do :
implementation
{$R *.dfm}
Series1.BeforeDrawValues:=SeriesBeforeDraw;
procedure TForm1.SeriesBeforeDraw(Sender: TObject);
Function SeriesRect(Series:TChartSeries):TRect;
With result do
Left:=Series.GetHorizAxis.IStartPos;
Right:=Series.GetHorizAxis.IEndPos;
Top:=Series.GetVertAxis.IStartPos;
Bottom:=Series.GetVertAxis.IEndPos;
// Clip
With Chart1 do
if CanClip then
Canvas.ClipRectangle(SeriesRect( Sender as TChartSeries ));
end.
Post
by Marc » Thu Jul 01, 2021 9:15 am
Update to previous answer. The Clip in OnAfterDraw should apply to the Chart rectangle.
ie.
Chart1.Canvas.ClipRectangle(Chart1.ChartRect); //<--here
x1:=Series1.CalcXPos(20); ...etc
Chart1.Canvas.UnClipRectangle;
