Wrong behavior: MaxPointsPerPage and two Series
DI
Post by DI » Tue Mar 23, 2004 9:59 am
Situation:
Two Series; XValues.DateTime := true;
different number of points (!); the same time-intervall (!):
Fill Series using AddXY; set MaxPointsPerPage property.
Behavior1:
Series0 has more points than Series1 => Chart is OK
Behavior2:
Series1 has more points than Series0 => Chart calculates NumPages using Series1, but drawing is wrong.
Example:
- Series0: 10 Points
- Series1: 50 Points
- MaxPointsPerPage: 10
- NumPages: 6
- Series are not streched correctly!
Post by Pep » Thu Apr 15, 2004 2:01 pm
which TeeChart Pro version are you using ?
I've just test it here withe the latest TeeChart Pro v7 and works fine.
DI
Post by DI » Mon Apr 19, 2004 7:05 am
I am using "TeeChart Pro 5.02 VCL".
Post by Pep » Mon Apr 19, 2004 11:06 am
yes, it has been solved for the TeeChart Pro v6 amd above.
DI
Post by DI » Mon Apr 19, 2004 11:33 am
It's a pity. It is not easy for me to update this components. Could you fix the problem in version 5.02 or can you tell me, how I can do that?
Post by Pep » Tue Apr 20, 2004 6:09 pm
are you source code customer ?
DI
Post by DI » Wed Apr 21, 2004 7:49 am
Yes, I am.
