Mark tips Style
IQSoft
Mark tips Style
Post by IQSoft » Wed Jun 18, 2008 8:15 am
Is there a way to display in mark tips Series name and X.Y values??????
Alex
Post by Yeray » Wed Jun 18, 2008 9:32 am
Hi Alex,
Yes, with OnGetMarkText event, from your series, you can customize its mark text as you want:
  Series1.Marks.Visible := True;
procedure TForm1.Series1GetMarkText(Sender: TChartSeries;
  ValueIndex: Integer; var MarkText: String);
    MarkText := Sender.Name + '   X: ' + floattostr(Sender.XValues.Items[ValueIndex]) +
              '   Y: ' + floattostr(Sender.YValues.Items[ValueIndex]);
IQSoft
Post by IQSoft » Wed Jun 18, 2008 10:18 am
If i undestand well you mean you can customize the text of the marks on the chart.....
I want to use the MArk Tips Tools and display Name , X,Y value....
Is it possible
Post by Narcís » Wed Jun 18, 2008 10:23 am
Hi IQSoft,
Yes, the MarkTips tool display marks text even if it's customized.
IQSoft
Post by IQSoft » Wed Jun 18, 2008 11:16 am
it can be customized the same way?????
Alex
IQSoft
Post by IQSoft » Wed Jun 18, 2008 11:17 am
I can be customized by code or by the user ( editing the diagram???)
Post by Narcís » Wed Jun 18, 2008 11:36 am
Hi Alex,
It can be customized programmatically using the OnGetText event.
IQSoft
Post by IQSoft » Thu Jun 19, 2008 11:45 am
Can i have a small sample of customizing text?????
Alex
Post by Narcís » Thu Jun 19, 2008 12:02 pm
Hi Alex,
You just need to add a TMarksTipTool to your application and make series marks not visible. The code Yeray posted will modify tool's text as well, for example:
  Series1.Marks.Visible := False;
  MarkText := Sender.Name + ' X: ' + FloatToStr(Sender.XValues.Items[ValueIndex]) +
              ' Y: ' + FloatToStr(Sender.YValues.Items[ValueIndex]);
