Smooth function not working in 8.0.4????
johnnix
Post by johnnix » Fri Jan 30, 2009 10:45 am
Hello all
I posted an example project in the newsgroups. Am I doing something wrong and the smoothing function does not work?
Post by Yeray » Fri Jan 30, 2009 11:30 am
Hi jonnyx,
Yes, this is a known bug (TV52010768) in the wish list to be fixed as soon as possible. It seems that this function doesn't work properly with some series.
johnnix
Post by johnnix » Fri Jan 30, 2009 1:25 pm
I am using the dcu version so I guess I have to wait for a new update? Can you please verify which version should I use (eg 8.0.2) so that the function should be working?
Post by Narcís » Fri Jan 30, 2009 2:48 pm
Hi johnnix,
Yes, exactly. You should wait for a new release. Current version is v8.04 but this issue is still present there.
johnnix
Post by johnnix » Sat Jan 31, 2009 9:06 am
Hello Narcis,
If my memory serves me well in version 8.02 the smoothing function worked ok. Can you please confirm this so that I roll back to this version. Unfortunately after upgrading to 8.04 I released an update for my software which had nothing to do with the plots so I did not test the smoothing function and now it looks like my users are complaining a little :)
Post by Narcís » Mon Feb 02, 2009 8:37 am
Hi johnnix,
I can't confirm this but according to the bug date I'd say it should also happen with v8.02. Anyway, this version is also available at the client area so you can download it and make the tests.
johnnix
Post by johnnix » Mon Feb 02, 2009 8:43 am
Hello Narcis,
Thank you for your reply. Do you have any fix date on when the new version will be released?
Post by Narcís » Mon Feb 02, 2009 9:03 am
Hi johnnix,
We don't have a fixed date yet but I think we could expect a new maintenance release by the end of this quarter of beginning of next's.
johnnix
Post by johnnix » Wed Apr 22, 2009 7:34 am
I need to release an update for my software soon but I am a dcu only customer and I have a problem with the smoothing function (TV52010768). Is this fixed already? If I purchase the sources should I be able to fix this by myself?
Post by Yeray » Wed Apr 22, 2009 7:51 am
Hi johnnix,
I'm afraid that this issue isn't still solved and the coming maintenance release is almost closed.
Yes, having the sources you'll be free to modify everything you want.
johnnix
Post by johnnix » Wed Apr 22, 2009 9:07 am
Hello Yeray,
Thank you very much for your reply. I guess that I will receive some guidelines on where to search for a fix when I have the full sources?
Post by Yeray » Wed Apr 22, 2009 9:33 am
Hi johnnix,
We can indicate you where those features are implemented but can't provide support to source code modifications.
johnnix
Post by johnnix » Mon May 11, 2009 12:58 pm
Today I purchased the source code version in order to trace the error regarding the smoothing function. I did not knew where to start so I first looked inside the Interpolate function and noticed that for every calculated point, X and Y values where identical....strange? After a while I ended looking at the AddPoints procedure and modified a portion like:
With Source do
      for t:=0 to Count-1 do
        if ParentSeries.YMandatory then
           //BSpline.AddPoint(XValues.Value[t],tmpList.Value[t])
           BSpline.AddPoint(XValues.Value[t],YValues.Value[t])
           //BSpline.AddPoint(tmpList.Value[t],XValues.Value[t]);
           BSpline.AddPoint(YValues.Value[t],XValues.Value[t]);
        BSpline.Knuckle[t]:=False;
Although I do not know where to look for the YMandatory property I run my app and for both cases (YMandatory = true or false) the code above seems to work ok. Can you please check this and let me know if I am in the right path?
Post by Narcís » Mon May 11, 2009 3:57 pm
Hi johnnix,
I think this will work in most cases. However, a more generic implementation would be this:
      With Source do
           BSpline.AddPoint(YValues.Value[t], tmpList.Value[t]);
I've checked it works fine and I'll add the fix for the next maintenance release which we expect to be published soon.
johnnix
Post by johnnix » Tue May 12, 2009 5:35 am
Hello Narcis,
I tested your code and it does not work ok for me (when YMandatory = true)... the following works ok
           BSpline.AddPoint(tmpList.Value[t],YValues.Value[t])
Anyway, I will keep my edit as it is and wait for the official release! Thank you very much for your support.
