Rewind to TChart that comes with BC6
E Mann
Post by E Mann » Thu Mar 05, 2009 10:41 am
Can someone tell me how I undo TeeChart v8 installation (which has failed) and get back to a standard BC6 TChart.
I have run the uninstall but I now get a link error when I drop a TChart on a form: [Linker Error] Unable to open file 'TEERESOU.RES'
Do I have to re-install BC6?
Post by Yeray » Thu Mar 05, 2009 11:38 am
Hi E Mann,
You should have your old teechart files in these backup folders:
C:\Program Files\Borland\CBuilder6\Include\Vcl\Backup_TeeChart
C:\Program Files\Borland\CBuilder6\Lib\Obj\Backup_TeeChart
You have two options:
1. "Radical": Cut or copy the files from the backup folders to the superior folder:
copy C:\Program Files\Borland\CBuilder6\Include\Vcl\Backup_TeeChart\*.* C:\Program Files\Borland\CBuilder6\Include\Vcl\
copy C:\Program Files\Borland\CBuilder6\Lib\Obj\Backup_TeeChart\*.* C:\Program Files\Borland\CBuilder6\Lib\Obj\
2. "Non destructive": Add old TeeChart backup files to your IDE's include and library paths:
add C:\Program Files\Borland\CBuilder6\Include\Vcl\Backup_TeeChart to Project/Options.../Directories-Conditionals.../Include path
add C:\Program Files\Borland\CBuilder6\Lib\Obj\Backup_TeeChart to Project/Options.../Directories-Conditionals.../Library path
And following any of the routes, you should revise also that the correct components are selected in the Project/Options.../Packages list
