Export to PDF from QReport does not work
Lenfors
Post by Lenfors » Wed Jun 10, 2009 7:38 am
Hello!
I'm using Quick Report 5.04.1 together with TeeChart Pro 8.05. When I have a chart placed on a QReport it works fine, but when I try to export to PDF the PDF document contains everything on the report except the TChart!?
Any ideas?
Regards, Mikael
Post by Yeray » Wed Jun 10, 2009 8:51 am
Hi Mikael,
Are you using TQRChart? What IDE are you using? How are you calling the exportation?
Lenfors
Post by Lenfors » Wed Jun 10, 2009 9:30 am
Yes, I'm using TQRChart. In QReports preview I can se my report including my TCharts, but when I from the preview try to save the report and select PDF format then a PDF file is created including everything in the report excluding my charts!
Regards, Mkikael
Post by Yeray » Wed Jun 10, 2009 10:00 am
Hi Mikael,
If you are using a QuickReport exportation method this problem shouldn't be TeeChart related as Marjan said here
