TColorLineTool problem
Leroy Casterline
Post by Leroy Casterline » Wed Jun 30, 2004 12:40 am
I'm trying to use the TColorLineTool to display vertical lines (markers in my terms) on a chart. I create a line at the cursor position when the user selects "drop marker" from a context menu. These markers are used to mark points of interest in the data being displayed, and are saved in a database table so they persist across application runs. This all works fine.
The problem I'm having is that when the chart is scrolled, the marker line move with the data as expected until it runs into the right or left edge of the chart. It then drags along the chart edge until the scrolling stops, and its initial position is lost.
If I set the NoDragLimit property to true, the line stays with the data, but doesn't vanish at the right or left chart axes - instead it is displayed over the right or left axis.
I want the line to travel with the data, and vanish when the associated data point is no longer visible on the chart.
How can I make this happen?
I am using BCB6 patch level 4 and TeeChartPro version 7.
Leroy Casterline
Post by Leroy Casterline » Wed Jun 30, 2004 3:59 pm
One more thing. When the line I'm dragging hits the left or right edge of the chart, I'd like the chart to scroll so the user doesn't have to drag the marker to an edge, drop it, scroll the chart manually, then drag again.
Post by Pep » Mon Jul 05, 2004 4:15 pm
Hi Leroy,
you can solve this using the following code, also seting the NoDragLimit property to true :
if (Charttool1.Value > Chart1.Axes.Bottom.Maximum) or (Charttool1.Value < Chart1.Axes.Bottom.Minimum) then
   Charttool1.Visible := false
   Charttool1.Visible := true;
This can be simulated by using the following code :
Series1.FillSampleValues(1000);
Chart1.MaxPointsPerPage := 100;
procedure TForm1.ChartTool1DragLine(Sender: TColorLineTool);
if charttool1.Value < Chart1.Axes.Bottom.Minimum +10 then
    Chart1.Axes.Bottom.SetMinMax(Chart1.Axes.Bottom.Minimum-10,Chart1.Axes.bottom.Maximum-10)
  if charttool1.Value > Chart1.Axes.Bottom.Maximum - 10 then
     Chart1.Axes.Bottom.SetMinMax(Chart1.Axes.Bottom.Minimum+10,Chart1.Axes.bottom.Maximum+10);
Leroy Casterline
Post by Leroy Casterline » Mon Jul 05, 2004 4:17 pm
Marjan or David, could you please help me out here?
Post by Pep » Mon Jul 05, 2004 4:23 pm
Hi Leroy,
have you seen my post ?
Leroy Casterline
Post by Leroy Casterline » Mon Jul 05, 2004 4:30 pm
Pep wrote:Hi Leroy,
We must have been posting at the same time. Your answer wasn't visible when I posted my latest message.
I realize that I can do this manually as you have pointed out. I was hoping that the TColorLineTool could handle this on its own. As it apparently can't, could you please add this behavior to the wish-list?
Thanks!
-Leroy
Leroy Casterline
Post by Leroy Casterline » Mon Jul 05, 2004 8:05 pm
I have one more question on the TColorLineTool. I need to display a hint where the cursor passes over or is held over the line.
I see that since I have drag enabled for the line, the cursor changes to a drag cursor when it is over the line and changes back to the default cursor when it is moved away. If I could get the line to fire events when the cursor changes I could show/hide my hints at that time.
Is there a way to display a hint or fire events when the cursor changes?
Post by Pep » Tue Jul 06, 2004 9:10 am
Hi Leroy,
Ok, I've added on our wish list to be considered for the next releases.
You could use similar code that in the example I've posted into the steema.public.attachments newsgroup.
Leroy Casterline
Post by Leroy Casterline » Thu Jul 08, 2004 6:20 pm
Pep wrote:Hi Leroy,
This works fine.
But this doesn't.
As the line I am dragging approaches within 10 units of either side of the chart, the chart scrolls as expected. The line I am dragging also scrolls, but the Drag Cursor does not travel with the line - it stays where the line was before the scroll.
Post by Pep » Thu Jul 08, 2004 6:51 pm
Hi Leroy,
I'm sorry, I'm not quite sure what you refer here when you says "Drag Cursor". Is that you're using one more Tool (Cursor Tool) ? Could you please be more specific ?
Leroy Casterline
Post by Leroy Casterline » Thu Jul 08, 2004 6:57 pm
Pep wrote:Hi Leroy,
When I move the cursor over the line, it changes to indicate that you can drag the line. This is what I was calling a Drag Cursor. The proper name for it is crHSplit.
Post by Pep » Fri Jul 09, 2004 8:39 am
Hi Leroy,
ok, I understand now. But here works fine using the TeeChart Pro v7 with BCB6 (the mouse cursor travels with the Line when drag). I've attached one example to the steema.public.attachments newsgroup. Could you please get it and test if it works fine for you ?
Leroy Casterline
Post by Leroy Casterline » Fri Jul 09, 2004 9:50 pm
Pep wrote:Hi Leroy,
Thanks, Pep. I built your project and am still having the problem. I don't think I explained it well - the cursor tracks the line OK until the line reaches either edge of the chart, then the chart scrolls and the line scrolls with it, but the cursor does not.
I've uploaded a zip file containing an AVI which shows the problem to the steema.public.attachments newsgroup.
Leroy Casterline
Post by Leroy Casterline » Wed Jul 14, 2004 3:37 pm
Pep, have you had a chance to look at this yet?
Post by Pep » Thu Jul 15, 2004 7:02 am
Hi Leroy,
sorry for delay. I'm not able to open the AVI files here. Could you please send them again directly to my mail account (pep@steema.com) ?
