Custom drawing on the Chart Panel
Chris.CHWU
Post by Chris.CHWU » Tue Feb 03, 2009 7:38 am
Dear Sirs,
How to remove "My Text" when I click "Clear Button"?
  Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        AddHandler TChart1.AfterDraw, AddressOf After_Draw
    Private Sub After_Draw(ByVal sender As Object, ByVal g As Steema.TeeChart.Drawing.Graphics3D)
        Dim Text As String = "My Text"
        Dim S As New Size(50, 50)
        Dim P As New Point(g.ChartXCenter - (S.Width / 2), g.ChartYCenter - (S.Height / 2))
        Dim R As New Rectangle(P, S)
        g.Pen.Color = Color.Blue
        g.Rectangle(R)
        g.TextOut(Convert.ToInt32(g.ChartXCenter - (g.TextWidth(Text) / 2)), Convert.ToInt32(g.ChartYCenter - (g.TextHeight(Text) / 2)), Text)
    Private Sub Clear_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Clear.Click
        'Remove "My Text"
Post by Yeray » Tue Feb 03, 2009 9:55 am
Hi Chris,
The easiest way I can think is to declare your "Text" variable as global and to change the string when the button is pressed:
        g.Rectangle(R)
        Text = ""
        TChart1.Refresh()
Post by Yeray » Tue Feb 03, 2009 10:10 am
Hi again Chris,
Another possibility to have more control would be using a global boolean and change it, instead of your string, when the button is pressed:
    Dim drawText As Boolean
        drawText = True
        If drawText Then
            g.Rectangle(R)
        End If
        drawText = False
        TChart1.Refresh()
