Color lines and zooming
Glenn F. Henriksen
Post by Glenn F. Henriksen » Mon Aug 09, 2004 3:15 pm
I am having a problem when I add 3 color lines to a chart and all 3 can be dragged. If you drag one of the lines and while dragging, the mouse moves down and to the right the chart zooms. Is there any way around this or any way to avoid this behavior?
Post by Pep » Mon Aug 09, 2004 4:31 pm
Hi Lancer,
are you using the Latest Binary version: 1st Aug. 2004 11:19 AM, Build 1.1.1675.27998 ?
I've test it here using it and this does not happens.
Glenn F. Henriksen
Color lines and Zooming
Post by Glenn F. Henriksen » Mon Aug 09, 2004 5:36 pm
Yes I am using the latest build. Also, the last line you add will work fine but the first 2 will not. To reproduce this add 3 color lines to the bottom axis and then drag one from the top left of the chart to the bottom right of the chart. The chart will zoom when the line is dragged. We are planning a release very soon. Any help would be appreciated.
Post by Pep » Thu Aug 12, 2004 12:30 pm
Hi Lancer,
see my other posts...
