2D Line chart problem with Top and Bottom series
qcrnd
Post by qcrnd » Wed May 20, 2009 11:53 am
In my 2D line chart the top series and bottom series seem to be cut
see attached image
Please advise
thanks.
Post by Yeray » Wed May 20, 2009 2:42 pm
Hi qcrnd,
I recommend you to define a bigger left axis minimum and maximum offset.
qcrnd
Post by qcrnd » Sun May 24, 2009 6:34 am
The problem is that If defined the MinimumOffset to something larger , I get the horizontal grid line on the zero point a few pixels above the bottom axis , instead of them being aligned and it doesnt look so nice.
Is there any way I can remove only the first horizontal grid line ? The grid line at the 0 value.
Post by Yeray » Mon May 25, 2009 8:35 am
Hi qcrnd,
No, I'm afraid that's not possible. However you could try to achieve a better result playing with these properties:
tChart1.Axes.Left.Grid.Centered = false;
tChart1.Axes.Left.Grid.DrawEvery = 2;
If you still don't get a nice looking chart, please try to send us a simple example project we can run as-is to reproduce the problem here and we'll try to think more solutions to make your chart look better if possible.
qcrnd
Post by qcrnd » Mon May 25, 2009 10:36 am
Hi Yeray
It wont help, I need the DrawEvery to be set to 1 because I calculate them to be alined with the ticks.
I will try and send you a sample application some time later
thanks.
