space isssue
Neelam
Post by Neelam » Wed May 27, 2009 7:08 am
hey, thanks so much for sending the solution. I tried the code , the only issue is now taht i have vb.net and this is in c sharp. so i tried to convert it, but at this line
tChart1.GetAxisLabel += new Steema.TeeChart.GetAxisLabelEventHandler(tChart1_GetAxisLabel);
it gives error.. it sauys use raoise event.. but when i use taht it does not take.
Can u send me its equivalent vb.net code. thanks so much for ur help.
Neelam
Post by Neelam » Wed May 27, 2009 7:14 am
i tried to convert using a utility..
Private Sub InitializeChart()
chartController1.Chart = tChart1
tChart1.Series.Add(New Steema.TeeChart.Styles.Bar())
tChart1.Series(0).Add(123, "really long long label 1", Color.Red)
tChart1.Series(0).Add(456, "really long long label 2", Color.Blue)
tChart1.Series(0).Add(321, "really long long label 3", Color.Green)
tChart1.Axes.Bottom.Labels.Angle = 90
tChart1.GetAxisLabel += New Steema.TeeChart.GetAxisLabelEventHandler(tChart1_GetAxisLabel)
Private Sub tChart1_GetAxisLabel(ByVal sender As Object, ByVal e As Steema.TeeChart.GetAxisLabelEventArgs)
If e.LabelText.Length > 16 Then
Dim tmp1 As String = e.LabelText.Substring(0,16)
Dim tmp2 As String = e.LabelText.Substring(16,e.LabelText.Length-16)
e.LabelText = String.Format("{0}{1}{2}", tmp1, "\n", tmp2)
End If
'BUT it gives error - Use a raiseevent statement to raise an event at this line- " tChart1.GetAxisLabel += New Steema.TeeChart.GetAxisLabelEventHandler(tChart1_GetAxisLabel)"
Post by Sandra » Wed May 27, 2009 10:36 am
Hello shikha,
The example code of VB is next:
Form_Load:
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        InitializeChart()
InitializeChart:
        ChartController1.Chart = TChart1
        TChart1.Series.Add(New Steema.TeeChart.Styles.Bar())
        TChart1.Series(0).Marks.Visible = False
        TChart1.Series(0).Add(123, "really long long label 1", Color.Red)
        TChart1.Series(0).Add(456, "really long long label 2", Color.Blue)
        TChart1.Series(0).Add(321, "really long long label 3", Color.Green)
        TChart1.Axes.Bottom.Labels.Angle = 90
GetAxisEvent:
  Private Sub tChart1_GetAxisLabel(ByVal sender As Object, ByVal e As Steema.TeeChart.GetAxisLabelEventArgs) Handles TChart1.GetAxisLabel
            Dim tmp1 As String = e.LabelText.Substring(0, 16)
            Dim tmp2 As String = e.LabelText.Substring(16, e.LabelText.Length - 16)
            e.LabelText = String.Format("{0}{1}{2}", tmp1, vbCrLf, tmp2)
        End If
I have assigned GetAxisLabels event at design time, because it's more easy. Please check that this code works fine.
I hope that will helps.
Neelam
Post by Neelam » Tue Jun 02, 2009 11:05 am
great this works but..
just one thing it pushes the chart up(that is make size of chart smaller). But the whole idea of doing this is taht the chart size does not change and does not become small.Infact there is lot of empty space belowthe labels in this case. how can we resolve that?
Post by Yeray » Tue Jun 02, 2009 11:40 am
Hi shikha,
Try playing with the following properties until you'll find your desired combination:
TChart1.Panel.MarginBottom = 0
Chart1.Axes.Bottom.RelativePosition = -12
Neelam
Post by Neelam » Tue Jun 02, 2009 12:11 pm
where exactly these 2 lines should be placed .. i mean at which event?
Post by Yeray » Tue Jun 02, 2009 1:01 pm
Hi shikha,
In a beginning you should modify your chart aspect at chart creation. If your labels change at any event, maybe you should do some calculations and change your chart aspect there.
Re: space isssue
Post by Narcís » Mon Jul 20, 2009 9:12 am
Hi shikha,
For topic consistency and so that it is easier for everyone to follow each topic I splitted your last post into another thread as it's a problem different from what was originally discussed here. You can follow the new thread here:
http://www.teechart.net/support/viewtop ... =4&t=10020
We will appreciate that you start a new thread for each different technical inquiry not related to an existing topic.
Re: space isssue
Post by Narcís » Mon Jul 20, 2009 9:16 am
Hi shikha,
Sorry, I wrongly splitted the first topic instead of the last, new topic is this one:
http://www.teechart.net/support/viewtop ... =4&t=10021
