ColorGrid reset the StartColor & EndColor values
vivek
Post by vivek » Tue Jul 21, 2009 5:28 am
Dear Support,
In colorgrid we want to reset the StartColor and EndColor values for series values. For example if the series values are 1,2,3,4,5,6,7,8,9 and 10 then StartColor white will be assigned to value 1 and EndColor red will be assigned to 10 in color grid, but if I want to assign the start color value as 5 instead of 1 and end color value as 8 instead of 10 then how to achieve this.
Faster reply will be appreciated.
Muthu Kumar
Gvs_Kumar@jubilantbiosys.com
Jubilant Biosys.
Re: ColorGrid reset the StartColor & EndColor values
Post by Sandra » Tue Jul 21, 2009 9:37 am
Hello vivek,
If you want to assigned diferents colors in the colorgrid, you need to use a custom palette. I recomened that see this post, that explain exactly how do for creat a custom palette.
I hope will helps,
vivek
Post by vivek » Tue Jul 28, 2009 6:04 am
Dear Sandra,
Please see the attachment to understand my requirements and reply. I had gone through your link and it will not serve my purpose.
Thanks again,
Muthu Kumar
Jubilant Biosys.
ColorGrid StartColor and EndColor value customization.gif (66.68 KiB) Viewed 10159 times
Post by Sandra » Tue Jul 28, 2009 10:57 am
Hello vivek,
I think, you should assign a palette for each of the color grids. Please, try to assign the palettes, and check that solve your problem.
I hope that will helps.
vivek
Post by vivek » Wed Jul 29, 2009 6:43 am
Dear Sandra,
In that case I can't scale the color across the grid from min.(white) color value to max.(red). Moreover it will degrade the performance.
Muthu Kumar
Jubilant Biosys.
Post by Sandra » Thu Jul 30, 2009 8:17 am
Hello vivek,
I have made an example, that you could use for solve your problem of ColorGrid using 2 palettes. Please check that next example solve your problem.
        Steema.TeeChart.Styles.ColorGrid colorgrid1;
            colorgrid1 = new Steema.TeeChart.Styles.ColorGrid(tChart1.Chart);
            Random rnd = new Random();
            int count;
            count = 0;
            double[] xValues = new double[48];
            double[] yValues = new double[48];
            double[] zValues = new double[48];
            for (double x = 0; x < 6; ++x)
                for (double y = 0; y < 8; ++y)
                    xValues[count] = x;
                    zValues[count] = y;
                    if (rnd.Next(100) <= 25)
                        yValues[count] = rnd.Next(100) - 25;
                        yValues[count] = rnd.Next(100);
                        ++count;
            colorgrid1.Add(xValues, yValues, zValues);
            colorgrid1.Marks.Visible = true;
            colorgrid1.Marks.Transparent = true;
            colorgrid1.UsePalette = true;
            colorgrid1.UseColorRange = false;
            colorgrid1.Palette.Clear();
                    colorgrid1.AddPalette(-15, Color.FromArgb(255,255,255));
                    colorgrid1.AddPalette(0,Color.FromArgb(255,220,220));
                    colorgrid1.AddPalette(10, Color.FromArgb(255,189,189));
                    colorgrid1.AddPalette(20, Color.FromArgb(255,179,179));
                    colorgrid1.AddPalette(30, Color.FromArgb(255, 149, 149));
                    colorgrid1.AddPalette(40, Color.FromArgb(255, 138, 138));
                    colorgrid1.AddPalette(60, Color.FromArgb(255, 0, 0));
                    colorgrid1.AddPalette(61, Color.FromArgb(0,0,255));
        private void AddPallete_Click(object sender, EventArgs e)
                    colorgrid1.AddPalette(-15, Color.FromArgb(255, 255, 255));
                    colorgrid1.AddPalette(0, Color.FromArgb(0, 0, 0));
                    colorgrid1.AddPalette(10, Color.FromArgb(255, 189, 189));
                    colorgrid1.AddPalette(20, Color.FromArgb(255, 179, 179));
                    colorgrid1.AddPalette(61, Color.FromArgb(0, 0, 255));
               tChart1.Refresh();
            tChart1.Series.Clear();
