When I use the Metafile property of TChart I always get an image height of 65535 - regardless of the actual TChart size.
Any idea what could cause that?
The TeeChart version used is 2.0.2987.19069
Thank you for your help!
Best regards,
Manuel
Metafile height is always 65535
Re: Metafile height is always 65535
Hello Manuel,
I couldn't reproduce your problem using last version 2 and next code:
Could you please, check if previous code works fine for you?
Steema.TeeChart.Styles.Line series1;
series1 = new Steema.TeeChart.Styles.Line(tChart1.Chart);
series1.FillSampleValues();
tChart1.Refresh();
tChart1.Export.Image.Metafile.EMFFormat = System.Drawing.Imaging.EmfType.EmfOnly;
tChart1.Export.Image.Metafile.Save("c:\\teeChartEmfOnly.emf");
tChart1.Export.Image.Metafile.EMFFormat = System.Drawing.Imaging.EmfType.EmfPlusDual;
tChart1.Export.Image.Metafile.Save("c:\\teeChartEmfPlusDual.emf");
tChart1.Export.Image.Metafile.EMFFormat = System.Drawing.Imaging.EmfType.EmfPlusOnly;
tChart1.Export.Image.Metafile.Save("c:\\teeChartEmfPlusOnly.emf");
Hi Sandra
It seems, that the problem only occurs when a series contains values which would appear outside the chart's bounds. For example, if you add double.PositiveInfinite and double.NegativeInfinite values to an area series while setting the y-axis scale to 0...1 you should encounter the same issue.
Best regards,
Manuel
Best regards,
Manuel
Hello Manuel,
I could not reproduce it here with last version 2 of TeeChart.Net. Could you please, send us a simple example, because we can reproduce your problem exactly here?
Hi Sandra
Please find attached a small project which demonstrates the issue.
Have fun!
Manuel
Have fun!
Manuel
- TeeChartDemo.zip
- (15.2 KiB) Downloaded 320 times
Hello Manuel,
Thanks for your project. I can reproduce your problem with height in last version 2 but not in last version 4. I strongly recommend you to download the fully functional evaluation version available at http://www.steema.com/evaluation/net and check again if problem persist. Moreover, I suggest a workaround using BITMAP image that seems works correctly for version 2:
Debug.Assert(tChart1.Size.Equals(tChart1.Metafile.Size), "Size of the metafile is not equal to the chart size");
bool bgEnabled = false;
for (int i = 0; i < 4; i++)
TimeSpan t = new TimeSpan(0, 0, i);
tChart1[0].Add(t.TotalDays, bgEnabled ? double.PositiveInfinity : double.NegativeInfinity);
tChart1[1].Add(t.TotalDays, Math.Sin(i));
bgEnabled = !bgEnabled;
