specify the size of the customization dialog
SRing
Post by SRing » Thu Feb 07, 2013 11:10 pm
Is it possible to specify the size of the customization dialog. I've attached a jpg that shows the problem. Some parts get cut off by default, and it would be nice to avoid this.
Re: specify the size of the customization dialog
Post by Sandra » Fri Feb 08, 2013 12:30 pm
Hello SRing,
You can change the size of Editor using next suggestion code:
Editor editor1;
           Steema.TeeChart.Styles.Line line = new Line(tChart1.Chart);
           line.FillSampleValues();
           editor1 = new Editor(tChart1);
           editor1.Width = 800;
           editor1.Height = 500;
Could you tell us if previous code works as you want?
SRing
Post by SRing » Fri Feb 08, 2013 5:17 pm
This seems to work. I had just been using
TeeChart.Editor.Show(plot)
Do I need to be doing something to copy options or anything from the static editor, or will this function identically?
Post by Sandra » Mon Feb 11, 2013 9:48 am
Hello SRing,
You need use the methods of Editor component if you would change the size of editor, because when you use Steema.TeeChart.Editor.Show(tChart1); you would work with a default size of TChart1 editor , therefore you cannot change the size editor directly, you need use editor component, assign custom size and call the ShowModal method as do in next code.
 editor1 = new Steema.TeeChart.Editor(tChart1);
            editor1.ShowModal();
