Problem Graphic 3D
"Alias"
Re: Problem Graphic 3D
Post by "Alias" » Mon Jan 18, 2010 12:06 pm
it's ok..
and about the elevation problem? is it in the wish list too?
thank you!
Post by Yeray » Mon Jan 18, 2010 2:44 pm
Hi Alias,
No, I don't still think that the elevation is showing any problem here. The problem is that using custom drawing you have to be careful with the order of the figures you are drawing. Take a look at this:
            If (((tChart.Aspect.Elevation < 180) And (tChart.Aspect.Elevation > 0)) Or (tChart.Aspect.Elevation < -180)) Then
                'Parte de baixo
                g.Brush.Color = Color.Orange
                rect = New System.Drawing.Rectangle(Xcentro - 96, Ycentro + 22, 192, 43)
                g.Cone(True, rect, Zcentro - 96, Zcentro + 96, True, 100)
                ''Parte do meio
                g.Brush.Color = Color.Gray
                rect = New System.Drawing.Rectangle(Xcentro - 104, Ycentro + 10, 208, 12)
                g.Cone(True, rect, Zcentro - 104, Zcentro + 104, True, 100)
                'Parte de cima
                rect = New System.Drawing.Rectangle(Xcentro - 96, Ycentro, 192, 10)
                Dim m(4) As Drawing.Point3D
                g.Brush.Color = Color.Yellow
                m(0) = New Steema.TeeChart.Drawing.Point3D(Xcentro - 50, Ycentro - 135, Zcentro) 'sup. dir.
                m(1) = New Steema.TeeChart.Drawing.Point3D(Xcentro - 50, Ycentro - 20, Zcentro) 'inf. dir.
                m(2) = New Steema.TeeChart.Drawing.Point3D(Xcentro - 100, Ycentro - 20, Zcentro) 'inf. esq.
                m(3) = New Steema.TeeChart.Drawing.Point3D(Xcentro - 100, Ycentro - 40, Zcentro) 'int. esq.
                m(4) = New Steema.TeeChart.Drawing.Point3D(Xcentro - 70, Ycentro - 135, Zcentro) 'sup. esq.
                g.Polygon(m)
                g.Pen.Width = 1
                'mastro
                g.Brush.Color = Color.Gainsboro
                rect = New System.Drawing.Rectangle(Xcentro - 50, Ycentro - 155, 8, 155)
                g.Cone(True, rect, Zcentro - 4, Zcentro + 4, True, 100)
                Dim p(3) As System.Drawing.Point
                p(0) = New System.Drawing.Point(Xcentro - 60, Ycentro - 155)
                p(1) = New System.Drawing.Point(Xcentro - 30, Ycentro - 155)
                p(2) = New System.Drawing.Point(Xcentro - 30, Ycentro - 155)
                p(3) = New System.Drawing.Point(Xcentro - 60, Ycentro - 155)
                g.Plane(Zcentro - 25, Zcentro + 25, p)
                g.Brush.Color = Color.White
                'est. met.
                rect = New System.Drawing.Rectangle(Xcentro - 55, Ycentro - 195, 4, 40)
                g.Cone(True, rect, Zcentro + 18, Zcentro + 22, True, 100)
                'gps
                rect = New System.Drawing.Rectangle(Xcentro - 39, Ycentro - 175, 4, 20)
                'sinalizador
                rect = New System.Drawing.Rectangle(Xcentro - 51, Ycentro - 190, 12, 35) '45
                g.Cone(True, rect, Zcentro - 6, Zcentro + 6, True, 100)
                rect = New System.Drawing.Rectangle(Xcentro - 40, Ycentro - 165, 6, 10)
                g.Cone(True, rect, Zcentro - 23, Zcentro - 17, True, 100)
                'antena
                rect = New System.Drawing.Rectangle(Xcentro - 55, Ycentro - 200, 4, 45)
                g.Cone(True, rect, Zcentro - 22, Zcentro - 18, True, 100)
            Else
                'antena
                'sinalizador
                'gps
                'est. met.
                g.Pen.Width = 1
                'mastro
                g.Polygon(m)
                'Parte de cima
                ''Parte do meio
                'Parte de baixo
            End If
