Loading of Teechart dll - startup time very high, Performanc
Re: Loading of Teechart dll - startup time very high, Performanc
Post by Yeray » Tue Jun 15, 2010 2:51 pm
Hi Ajay,
It would be helpful if you could wait until the next maintenance release will be published because we are in the middle of the tests to finalize it. When we'll publish it, you'll be able to choose between signed and unsigned.
Post by Yeray » Mon Jun 21, 2010 9:31 am
Hi Ajay,
The mentioned maintenance release has been release as you can see here
PIC
Post by PIC » Fri Jul 02, 2010 6:25 am
We downloaded
TeeChartNET2010VSNET2005_4.0.2010.27961.exe
June 21, 2010
Build 4.0.2010.27960
File size - 23,6 MB
We see the performance problem with this version as well. We even doubt that the performance problem has increased.
We just did a Assembly.Load of the TeeChart dll and this call took 12 secs for the first load !!!
Please comment.
Ajay
Post by Yeray » Fri Jul 02, 2010 10:59 am
Hi Ajay,
Can't you see the file TeeChartNET2010x64UNSIGNED_4.0.2010.27961.EXE?
PIC
Post by PIC » Tue Jul 06, 2010 9:30 am
It seems that the performance has improved with the dll we got from the following file:
We need the 32 bit version of the above mentioned dll too. Could you please point out the download link for this?
We still have to do a detailed round of testing once we have both dlls (32 bit and 64 bit versions). I'll get back to you if any bugs are found.
Thanks for your time and cooperation.
Warm Regards,
Gaurav.
Post by Yeray » Thu Jul 08, 2010 3:59 pm
Hi Ajay,
We've prepared the 32 bit unsigned dll (4.0.2010.27961) and sent it by mail.
I hope it will give you the opportunity to do the desired tests satisfactory.
PIC
Post by PIC » Fri Jul 09, 2010 6:09 am
We haven't recieved any email with the 32-bit dll attached!
Please try sending the email to the following id:
Gaurav.Balani@Philips.com
Gaurav.
Post by Yeray » Fri Jul 09, 2010 7:15 am
Hi Gaurav,
Just sent it!
PIC
Post by PIC » Tue Jul 13, 2010 6:20 am
Thanks for the dlls you provided. Now we have encountered a minor issue:
The Teechart v1 dll we were using was used by a process developed long ago, and hence we want to leave it as it is for legacy reasons.
Hence, for our new applications we will want a teechart dll with a different name since both the dlls will be stored in the same directory. Could you provide us with the same 32 bit dll you provided on 09 Jul 2010 with a different name (preferably teechart32)?
Gaurav.
Post by Marc » Tue Jul 13, 2010 10:37 am
Hello Gaurav,
The TeeChart build process is quite complex and requires the build of many different versions of TeeChart to support different IDEs/Framework versions. It would be too complex for us to maintain alternative, additional names between versions. We suggest that you make a subdirectory at the location where you wish to store a different version of TeeChart and use the subdirectory name to manage your own version control system.
