TreatNull and fast line
Igor G
Post by Igor G » Sun Nov 08, 2009 1:27 pm
I have downloaded the trial 2009 version (build 4.xxx) of .NET teechart (using it with compact framework).
As I understand you claim for fixing the
[TF02014420]
FastLine Series TreatNull property not working
when DrawAllPoints is set to false.
Well, I have some non deterministic behaviour of this propery.
For some number of points it woks great but if I draw more points it can connect the last and the first points between the null values gap.
Or if I draw 2 graphs it may occur as well.
Do you know anything about this? We are considering to upgrade to 2009 (we have a previous version) but we need to be sure that this feature will work since we must have a FastLine...
Re: TreatNull and fast line
Post by Sandra » Mon Nov 09, 2009 11:53 am
Hello Igor G,
The bug is fixed in last version of TeeChart .Net 24th of September 2009, please see release notes. We couldn't reproduce your problem, using last version of TeeChart.Net (version 4). Please if your version isn't last update, please download last version and back to check if your application works fine using last version. If not works correctly please, you could send us a simple project, because we can reproduce the problem here.
Igor G
Post by Igor G » Mon Nov 09, 2009 12:20 pm
I know, I am using the lates version (trial).
My version is 4.0.2009.35595
But still it doesnt work good if I use a lot of points, or few graphs together.
I will try to reproduce it.
Where can I upload the project?
Post by Narcís » Mon Nov 09, 2009 2:07 pm
Hi Igor,
You can use the attachments feature in this forums, below the message box. You can also post your files at our upload page or at the news://www.steema.net/steema.public.attachments newsgroup.
Igor G
Post by Igor G » Tue Nov 10, 2009 9:01 am
Attached simple project demonstrating the bug.
I notices when I zoom in the gap area the connecting line dissapears....
ChartTest.rar
vs 2008 project suing compact framework
(341.38 KiB) Downloaded 987 times
Post by Narcís » Thu Nov 12, 2009 4:09 pm
Hi Igor,
The fix for TF02014420 still failed in some circumstances. We have enhanced it for the next maintenance release and tested that works fine now with your project.
Igor G
Post by Igor G » Sun Nov 15, 2009 10:26 am
Well these are good news.
However, will you fix this bug for older version TeeChart (not 2009) because our license is for this edition.
Post by Narcís » Mon Nov 16, 2009 11:54 am
Hi Igor,
Yes, I copied the fix from v2009 to v3 so that you can expect this to be fixed in next v3 release.
Igor G
Post by Igor G » Tue Nov 17, 2009 1:41 pm
Great thanks
I will wait for it.
Do you have any estimation about the time?
Post by Narcís » Tue Nov 17, 2009 1:47 pm
Hi Igor,
Not yet. Please be aware at this forum or subscribe to our RSS news feed for new release announcements.
