How do I individually set properties for points in a series?
Rookie_SP
Post by Rookie_SP » Sat Jul 10, 2004 8:53 am
How can I set different pointer styles or LinePen for different indexes in a line series in VB.NET?
For instance I would like to have even segments red and odd ones green in an alternate way. Same with circle and square pointers.
Help please!!
Post by Pep » Mon Jul 12, 2004 5:21 pm
you should be able to do this using the OnGetPointerStyle event (setting pointer Visible to true). The problem is that there's a bug in the drawing algoritm and does not paint correct pointers for individual points. It's added on our defect list and a fix for it will be considered to inclusion for the next maintenance releases. I meantime I've not found any workaround.
Glenn F. Henriksen
Is this fixed in the August 1 release ?
Post by Glenn F. Henriksen » Tue Aug 10, 2004 3:43 am
Pep wrote:Hi,
Is this fixed in the August 1 release (OnGetPointerStyle event) ? Can you provide an example of how to use it ?
KSB
Marjan
Post by Marjan » Tue Aug 10, 2004 6:25 am
Hi.
Sure, here is C# example, using series OnGetPointerStyle event:
    private void Form1_Load(object sender, System.EventArgs e)
      points2.FillSampleValues(10);
      points2.Pointer.Pen.Color = Color.Blue;
    private void points2_GetPointerStyle(Steema.TeeChart.Styles.CustomPoint series, Steema.TeeChart.Styles.CustomPoint.GetPointerStyleEventArgs e)
      // if even, yellow, otherwise blue
      if (e.ValueIndex % 2 == 0) points2.Pointer.Pen.Color = Color.Yellow;
      else points2.Pointer.Pen.Color = Color.Blue;
Additionally you can also change individual point Pointer.Style (by accessing e.Style).
Marjan Slatinek,
