2 color lines in the same value
acastro
Post by acastro » Mon Mar 22, 2010 8:49 am
When I have 2 colorLine's in the same value, by example if I see the blue coloLine when I try to drag it I drag the red one. If I change the order in the editor I see the red one but I move first the blue one. Can I change this behaviour?
Re: 2 color lines in the same value
Post by Sandra » Tue Mar 23, 2010 11:34 am
Hello wakeup,
I make a simple project that I think you can use in your application. Basically code uses a radio button, lets you choose, what colorline you want to drag.
        Steema.TeeChart.Styles.Bar bar1;
        Steema.TeeChart.Tools.ColorLine colorline1, colorline2;
            bar1 = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
            bar1.FillSampleValues();
            bar1.ColorEach = true;
            colorline1 = new Steema.TeeChart.Tools.ColorLine(tChart1.Chart);
            colorline2 = new Steema.TeeChart.Tools.ColorLine(tChart1.Chart);
            colorline1.Axis = tChart1.Axes.Bottom;
            colorline2.Axis = tChart1.Axes.Bottom;
            colorline1.Pen.Color = Color.Red;
            colorline2.Pen.Color = Color.Blue;
            colorline1.Draw3D = false;
            colorline2.Draw3D = false;
            //-------SELECT COLORLINE2-------//
            colorline2.AllowDrag = true;
            colorline1.AllowDrag = false;
            radioButton1.Checked = false;
        private void radioButton1_CheckedChanged(object sender, EventArgs e)
            if (radioButton1.Checked)
                colorline1.AllowDrag = true;
Please, check next code works as you want.
acastro
Post by acastro » Tue Mar 23, 2010 11:44 am
Sorry. I think you don't understand the problem.
I don't find usefull to use a checkbox only for the special cases both color lines are in the same value... It should be transparent for the user.
When both color lines are in the same value one over the other, I think it doesn't matter which moves first when I try to drag it, but I think it should be the one with the color is over.
Sorry, my english is a bit limitated.
Post by Yeray » Wed Mar 24, 2010 10:59 am
Hi wakeup,
Yes, it seems that the order followed to check what series is going to be dragged should go reverse. I've added it to the wish list to be revised asap (TF02014748).
